Old 03-06-2021, 03:32 PM #1
KosherBeefCake KosherBeefCake is offline
KosherBeefCake is on a distinguished road
Angry Lift Gate Window Regulator Help
I really need help with my rear window regulator.
I put my rear window down the other day, and the window wouldn't come back up; not great in the winter in Michigan. I took apart the lift gate, and found that the original regulator had rusted apart.
Over the last couple days, I've been trying to get the motor connected to the regulator, and I've been having a heck of a time. There has to be something I'm missing, or something must be wrong. I get that the regulator cable needs to be taught, but there's no way it has to be THIS tight.
I've been searching the forum, and from what I've read, everyone said it should be easy. I'm definitely missing something.
Lift Gate Window Regulator Help-img_4133-jpg  Lift Gate Window Regulator Help-img_4134-jpg  Lift Gate Window Regulator Help-img_4135-jpg  Lift Gate Window Regulator Help-img_4136-jpg
KosherBeefCake is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 02:09 PM #2
I've attached some better photos. I have the spring ends in the housing, compressed as far as they'll go with zip ties, and I'm still missing about a half an inch of slack. I disconnected the black end on one of the regulators, and it's TIGHT right now.
Does anyone have any suggestions on what to do? I've looked at past posts, and everyone says it's a super easy replacement. I HAVE to be missing something, right?
Lift Gate Window Regulator Help-img_4149-jpg  Lift Gate Window Regulator Help-img_4150-jpg  Lift Gate Window Regulator Help-img_4151-jpg
Old 03-07-2021, 05:54 PM #3
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
Looks like your motor assembly orientation is off, might have to twist it around and see what happens.
Here’s a photo from when I did mine, make note of the mounting tab for the motor assembly. Then try to replicate how the cables run.
Lift Gate Window Regulator Help-1e0d9421-1466-4ae1-90ef-0efef58e0667-jpg
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 09:13 PM #4
I figured it out! Now that I've figured it out, I feel like I could do it in 5 minutes.
If anyone runs into this issue in the future, it's all about getting the reel onto the motor mount. Don't bother disconnecting any of the slides, or anything like that; it's a waste of time, and won't get you to completion. Get the reel wound up, feed the lines through the nylon guide, and push the guide and reel onto the motor. It is difficult, I had to use needle-nose pliers to get it the last inch, but now it's on!
gate , lift , missing , regulator , window
Lift Gate Window Stuck Khenderson1102 4th Gen T4Rs 4 06-07-2019 06:24 PM
Link to parts required to replace window regulator in tail gate of 2005 4Runner SilverGs 4th Gen T4Rs 6 05-17-2018 04:31 PM
Lift gate window mechanism rust 8000m 5th gen T4Rs 6 09-01-2017 04:37 PM
Regarding the lift gate window switch MrEMan 4th Gen T4Rs 7 11-02-2015 03:37 PM
Drivers Front Power Window Lift Regulator with Motor 96-02 Toyota 4Runner judoant For Sale: T4R Items 0 10-26-2014 01:40 PM
