Old 03-09-2021, 11:53 PM #16
Clarkson! Clarkson! is offline
Real Name: Tristan
Clarkson! is on a distinguished road
Real Name: Tristan
Originally Posted by Drcoffee View Post
Dremmel a cut for a standard screwdriver. Then heat them with a plumbers torch until they smoke, then screw them out. Heat is your best friend.
Thanks for the suggestion. What are you using for heat? I have a benzomatic propane torch, but haven't had any luck. Was thinking of picking up an oxy-map torch but am concerned that might be too hot and damage/warp the surface of the head.
2005 SR5 4WD: V8 - Doug Thorley headers, Bilstein 5100s, Slee offroad steel brake lines, Tundra brake swap, JBA upper control arms, 33s on RockTrix wheels, etc.
Clarkson! is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 02:06 PM #17
triethylborane triethylborane is online now
triethylborane will become famous soon enough
That isnt as much of an issue as mechanically degrading the aluminum threads on the head and pulling them with the sheared bolt.
The benzo propane torch and be a bit stingy, you dont want the sheared bolt to get red hot. Let it completely cool, the drcoffe dremel suggestion is a good one.
As is pulling and taking it to a shop.
triethylborane is online now   Reply With QuoteReply With Quote
bolts , engine , head , mount , thought
Sheared Rear sway bar bolts snydmax 3rd gen T4Rs 4 04-22-2020 01:05 PM
Oil dipstick broke off b/c of sheared-off bolt head – Suggestions? eric_rosenwald 3rd gen T4Rs 9 10-11-2017 06:58 PM
Sheared bolts and seized bolts. Need help. mavrick1903 4th Gen T4Rs 8 07-18-2017 01:33 PM
Bolts sheared off of LBJ Dous 3rd gen T4Rs 39 06-27-2012 08:58 AM
Front Skid Plate Bolts Rusted/Sheared Off? EzyGlider 4th Gen T4Rs 4 10-03-2011 08:52 AM
