Old 03-08-2021, 10:23 AM #1
Cezar Cezar is offline
Cezar is on a distinguished road
Evaporator / Heater core replacement
I want to embark upon this project shortly. The evaporator finally gave up last year and I've been without AC since. I want to gather some info. Questions:
- Where do I find the most long-lasting evap / heater core parts? I never want to do this job again.
- I also have some blend door issues I want to resolve. Recirc no longer works and I have uneven air coming out of the vents. Should I replace every actuator? How many are there? Are they all identical?
- Any other parts I should be replacing while I'm in there?
- Does anyone have a basic outline of the steps involved? I can consult the shop manual for sub-tasks but a general outline would be really helpful.
- Is there a recent DIY anyone has put together?
- Any specialty tools I will need? I already have manifold gauges and a vacuum pump and all basic hand tools.
Cezar is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 11:49 AM #2
Stackman1 Stackman1 is offline
Stackman1 is on a distinguished road
Just had my mechanic perform this repair on my 2006 a few weeks ago. He installed a Four Seasons brand evaporator because he said it had a lifetime warranty. I'm having what I would consider wild fluctuations in AC temp and I'm wondering if these are normal, or if it could be due to the brand of evaporator he installed. AC vent temp jumps between 44-50. Not trying to hijack your thread, but if anyone has input on what I'm experiencing, perhaps it could save you some problems (if I'm actually having any problems).
_____________________________
2006 SR5 4x4 V6
OME 884/895e and Bilstein 5100’s
Stackman1 is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 02:19 PM #3
Sounds like either the refrigerant is low or high or a blend door issue. Check the pressures..
As far as a lifetime warranty on the evaporator-- I could care less about that. By the time I need it I've already lost.
Old 03-08-2021, 02:45 PM #4
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I have used this fix on other toyota / Lexus cars actuators and it works.
https://www.youtube.com/watch?v=s9S5B1Dn3j4&feature=youtu.be
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 09:43 PM #5
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Theres some good pics and info on Evap core replacement from @TheHennDoggg here:
Solo Evap Core Replacement- DONE! Pics and Info
y=mx+b is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 08:50 AM #6
Holy crap those are expensive. I figured they would be like $50. I'll be trying this.
This actually looks downright easy. What is it missing that is going to bite me?
Old 03-09-2021, 09:38 AM #7
Wozzy's Avatar
Wozzy Wozzy is offline
Wozzy is on a distinguished road
Wozzy's Avatar
It's not too bad of a job, just time consuming. One tool I wish I would have had at the time was an cordless ratchet (with a swivel and some extensions) as that would speed up the time considerably just to be able to zip off all the bolts.
Use cardboard and stick the bolts into it or use sandwich bags and label as this will help with the reinstall. I probably used about 20-30 bags to make sure everything went back where it went.
Grab an OEM heater core, it lasted over 200k miles and who knows how many engine hours at idle.
2007 Limited 4WD V6 | Shadow Mica | 290K
Wozzy is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 11:02 AM #8
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
Denso 476-0040 A/C Evaporator Core Amazon.com: Denso 476-0040 A/C Evaporator Core: Automotive
FordF150 is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 02:07 PM #9
Originally Posted by FordF150 View Post
I purchased it as well as a heater core. I have all the parts on the way for the job except the actuators. Still not sure if I want to try my hand at repairing them. It looks like there are some cheaper ones available.
I assume none of the actuators need the dash out to replace?
Old 03-10-2021, 08:46 PM #10
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Pretty sure what you have is a bad thermistor. It's mounts in the evaporator and basically cycles the compressor off to prevent the evaporator from freezing up. They go bad and cycle out at too high of a temp and keep it off too long. I had the same problem and it made a huge difference when I replaced it. It's kind of a pain to replace but it can be done without removing the dash or the evaporator. The thread I'm linking below will give you more information. Especially post #15. Oh, and be careful about the part number. It's different between year models. And it's one of those rare items that you can actually get from the dealer as cheap as or cheaper than on the net.
AC cycling on and off, hot and cold
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 12:43 PM #11
Thanks for the info and link!! I'll will pass this along when I have it evaluated.
2006 SR5 4x4 V6
basic , evaporator , heater , outline , parts
Evaporator/Heater core cleaning - Anyone done it? bjohnston115 5th gen T4Rs 43 07-19-2022 06:03 PM
A/C Evaporator Core Replacement jaxX- 4th Gen T4Rs 23 05-21-2021 10:39 PM
4th Gen Evaporator Core Replacement TungstenSquash 4th Gen T4Rs 13 10-04-2020 01:24 PM
AC Evaporator Core Replacement - non OEM parts? danthemanx07 4th Gen T4Rs 0 07-11-2018 12:30 PM
Evaporator Core Replacement tuteng 4th Gen T4Rs 0 07-15-2012 04:59 PM
