Old 03-15-2021, 05:50 PM #1
RazzRoach's Avatar
RazzRoach RazzRoach is offline
RazzRoach is on a distinguished road
RazzRoach's Avatar
JBA Upper Control Arms Rubbing?
I have Icon Stage 2 suspension and the Jba Upper Control arms. When I turn wheel almost full to either side such as back up out of parking space and drive forward there is a clunking noise. I don't have wheel spacers and am running 275's. Has anyone else had this problem?
RazzRoach is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 08:40 PM #2
RazzRoach's Avatar
RazzRoach's Avatar
anybody?!
Old 03-30-2021, 09:51 AM #3
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
Could be a few things.
1. Sway bar bushings
2. Sway bar end links
3. LCA bushings
4. Lower ball joints
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 11:06 AM #4
montijo505's Avatar
montijo505's Avatar
Have you done any clearancing for the bigger tires? Though not much bigger then stock, they are likely running the lower inside lip of the front bumper or the wheel well liner.
Old 03-30-2021, 11:54 AM #5
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Have you checked the front end components?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 03:37 PM #6
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
I'm on JBA High caster standard UCA's and I can tell you that for tire clearance they are worse than the factory arms because of the way they sweep out towards the joint to give you more pre-built caster.
I am on a 315 tire (35's) and my factory arm did not rub with my 17x9 -12et tire, soon as I installed the JBA's I noticed rubbing start at near full lock. I am on the Bilstein 5100/OME 3" suspension lift and 1" body lift.
With my setup, I estimate 1/2" spacer would have done the job, but since you can't run such a thin spacer without custom machining I just had 1" spacers delivered. Down the road I plan on getting a 9" wide wheel with something like a -20 to -30 offset to not have to run spacers.
With that said though, is this a new lift you just put on? New tires? a little more information would help. Do you have the body mounts chopped? It should be fairly easy to see what is rubbing.. just turn to full lock and get under the car and see what's going on.
aemravan is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 05:55 PM #7
RazzRoach's Avatar
RazzRoach's Avatar
I've had the lift on for a few months. No BMC. Currently running 265/70/17 but I ordered some new wheels -25 offset 17x9. It doesn't always happen at full lock but more when I am driving and go over speedbump or uneven terrain at full lock.
Old 04-04-2021, 07:35 PM #8
If that's the case I'm not sure if it's the UCA you're rubbing ? Can you see scuff marks on it ? The distance from the uca relative to the tire doesn't change much with up/down travel, does it ?
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
arms , control , jba , upper , wheel
FREEDOM Offroad Control Arms - Under $350 Tubular Upper Arms from Battle Born! Battle Born Offroad Suspension 26 06-14-2021 08:29 PM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
WTB: spc upper control arms for 5th gen t4r 10ac Want to Buy/Trade 0 04-16-2016 04:50 PM
Upper control arms same on the V-6 and V-8? redkaz04 4th Gen T4Rs 8 08-01-2015 09:25 AM
Getting some rubbing on Upper Control A Arms, What to do?? gkatmar 4th Gen T4Rs 2 10-15-2007 03:55 PM
