Old 03-16-2021, 07:26 PM #1
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Help w a clunk/ pop
For the last few weeks, I’ve noticed a clunk or pop coming from under around the middle of the vehicle.
It only happens when I brake for first the time after starting the car. Ie I drive to the end of the street and have to stop at the intersection and reliably I will get a clunk. Doesn’t happen thereafter when I’m driving. If I turn off the car and it’s still warm when I restart - running into the store quickly it won’t happen, only when it’s been sitting a while.
I had a different clunk a few months ago that turned out to be a loose caliper and I recently greased my driveline / propellar shaft. Nothing seems loose underneath.
Doesn’t seem too serious as it goes away.
Any thoughts?
Old 03-17-2021, 02:00 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Oddly doesnt happen when backing out of driveway, hitting brake and shifting to drive
Old 03-18-2021, 10:08 AM #3
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Probably just pad shift if you can't identify anything else.
Is is common to hear a loud noise when initially going from F-R or R-F. I believe the pads are tight to the rotor and that causes a thud when you start rolling and they shift suddently, hitting the calipers since there is a little bit of play in their resting location.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 10:32 AM #4
pearlj10 pearlj10 is offline
pearlj10 is on a distinguished road
You could try lubricating the caliper pins to see if that alleviates the issue. You’re confident that you squirted enough grease in the front (if 4WD) and rear driveshaft zerks? If they’ve been neglected, they can take a significant amount of grease. Good luck troubleshooting.
pearlj10 is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 11:51 AM #5
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I recall having this same type of mysterious clunk a few years ago. Turns out all of the inboard pistons on both front calipers were ceased.
Hopefully that isn't your issue, but it'd be worth checking.
There was no difference in brake performance for many months with the clunk. But then one day there was a notable difference in braking, so I took it in... and replaced all 4 calipers, rotors, and pads... and brake lines. Threw the book at it, as it were.
Hopefully a brake inspection at a reputable shop can discern where the problem is.
Best luck, hope this helps.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
car , clunk , doesn’t , happen , loose
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Clunk when let off gas @ 60-70 mph Tom P. 3rd gen T4Rs 4 05-16-2013 04:14 PM
Clunk clunk down the road ALt4r 4th Gen T4Rs 9 12-19-2008 08:36 PM
