Real Name: Newell
Real Name: Newell
Probably just pad shift if you can't identify anything else.
Is is common to hear a loud noise when initially going from F-R or R-F. I believe the pads are tight to the rotor and that causes a thud when you start rolling and they shift suddently, hitting the calipers since there is a little bit of play in their resting location.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
