Old 03-22-2021, 11:56 AM #1
T4R03 T4R03 is offline
T4R03 is on a distinguished road
2UZ oil change intervals
I used to always do 3,000 mile oil change intervals no matter what using conventional oil. I’ve since switched to synthetic and I have a little over 6,000. How often do you guys change your oil with synthetic? I’m looking to change mine soon.
T4R03 is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 04:09 PM #2
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
I personally do every 5,000 miles. But I have never sent oil for analysis or anything like that so I have no reasoning or logic other than personal preference. I think I recall reading somewhere about people doing 7500-10,000 with oil analysis to confirm that there were no issues with those intervals (on the 2uz).
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 05:09 PM #3
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
I just changed my oil after a bit over 6,000 miles. I usualy don't let it go that long although they claim synthetic oil will last 7,500-10,000 miles. I usualy change it twice a year-once as the the cold weather sets in in the fall and again 6 months later because having fresh oil in helps it turn over a bit easier when the temps outside hit sub zero. It's at bout 4,000 miles each time.
Hunter61 is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 09:24 PM #4
wsgoat's Avatar
wsgoat wsgoat is offline
wsgoat has a spectacular aura about wsgoat has a spectacular aura about
wsgoat's Avatar
Every 5k here (with OEM filter) on both of my rigs.
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
wsgoat is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 08:15 AM #5
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
The only way to know for sure the recommended intervals for your specific trucks is to have a lab like Blackstone analyze the oil for you after you've run your oil for your normal interval and let them advise you if it is safe for you to either extend your intervals, keep them the same, or shorten them.
Anything else is just guessing.
Blackstone Laboratories
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 10:10 AM #6
riverwolf riverwolf is offline
riverwolf is on a distinguished road
I aim for 5,000 mile changes, but sometimes that gets stretched to 7,500ish +/-. Basically, start thinking about an oil change when the reminder starts to flash (5000) and try to actually do it before it goes solid (7500). I've been running full synthetic for most of the 18 years I've owned the rig.
FWIW, Toyota shortened the recommended change interval, possibly with the addition of VVT-i on the 2UZ. In my '03 manual and onboard reminder, the recommended interval is 7500. I've seen later owner's manuals and possibly on the Toyota owner's site, that later 2UZs were reduced to 5,000 mile changes.
As Johnboy says, there's only one way to know for sure. But, even an analysis is subject to whatever driving conditions that particular fill experienced.
One can assume manufacturers are going to err on the conservative side in their maintenance recommendations (warranty). Now, how comfortable you are in exceeding that specification is up to you. I haven't been able to bring myself to push 10,000, yet. I always think back to the NYC Taxi study back in the ?80s? when the written-in-stone rule was 3000 mile changes. Even with the muck that passed for motor oil at the time, oil analysis said the cabs were good for 6000+, IIRC. Maybe the internet still has that information archived somewhere, if you're really curious.
FWIW, even as far back as the 4th Gen...a number of manufacturers had already started using the onboard computer to monitor engine parameters that impact oil life to notify the owner when a change was due instead of using a fixed interval. For instance, the BMW straight sixes of similar vintage to the 2UZ will allow up to 12000 miles, maybe more, depending on driving conditions. Our company Silverado trucks with the 5.3 liter V-8s allow 15000 miles, maybe more, between changes...how old is that engine design? Main difference is the quality of the oils.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 10:38 AM #7
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
Mobil 1 oil every 5000 miles with a Toyota filter. Though I don't sweat going to 6000 if the weather won't co-operate.
Edit: realized you were asking about the V8 engine. My answer would be the same though.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 12:27 PM #8
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
This. Driving styles vary. Oils vary. Climate varies. Your engine may vary, too.
6,000 miles (10,000 km) should be safe to do on synthetic. Probably further.
If you are concerned about maybe throwing away good oil, or even worse --excessive wear or damage from using depleted oil-- pay for a UOA or two to make sure of your interval.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 10:08 PM #9
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Usually 9k to 12k running Toyota YZZD3 filter and Rotella T6. Blackstone has confirmed that there is a good amount of additives still present at those mileages still so I haven't been worried about it. 302k miles on it now.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 05:27 AM #10
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
15,000 to 25,000 miles with Amsoil Signature and Amsoil filter.
When I was running Mobil 1, I did every 3,000 miles which ended up taking 6 months or more to acquire. 5,000-7,500 seems to he what most people do.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 06:41 PM #11
Barefoot Barefoot is offline
Barefoot is on a distinguished road
every 5K, mainly because it's easy to keep track.
Barefoot is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 08:02 PM #12
djkurious djkurious is offline
djkurious is on a distinguished road
5k with here along with rotate and balance.
2003 4Runner SR5 V8
319k and counting...
djkurious is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 11:47 PM #13
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I have been doing 1yr/10k oil changes with a sample sent to BlackStone on Amsoil 5w-30 Signature Synthetic with their extended interval oil filter. Been getting good results with that, but I might go down to 5k intervals since I idle the vehicle quite a bit on my lunches and I haven't been driving as much as I used to.
BlackWorksInc is offline   Reply With QuoteReply With Quote
2uz , change , intervals , oil , synthetic
ATF Change Intervals for Normal Service Only DougR 5th gen T4Rs 21 01-07-2023 04:01 PM
Fluid Change Intervals (Other than oil) desertred 5th gen T4Rs 12 08-18-2020 11:19 PM
Maintenance Intervals Mannheim62 4th Gen T4Rs 16 05-19-2013 12:54 AM
Me vs the dealer (oil change intervals) swansong04 5th gen T4Rs 15 03-27-2013 04:32 PM
For those hesitant about extended oil change intervals... Toyodas Maintenance/Detailing 3 10-28-2010 07:25 PM
