Old 03-23-2021, 10:45 AM #1
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
broke one of front bumper bolts during install
the bottommost bolt on the side with the 3 bolts (and there 1 on the other side of flange) i brokeloose the inside bolts and then was taking the bottom bolt off on other side and undercoating (bangs head) was on the threads and it led to me snapping the bolt off. should i continue removing all the other 7 bolts (hopefully without breaking any) and then drill out the broken stud and just replace with a large bolt for bumper install? these appear to be fixed studs that the new bumpers attach to.
thanks everyone, ughhh
hinmo24t is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 09:54 AM #2
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
You're talking about the 14mm socket bolts that hold the factory crash bar to the frame rails, correct?
Try the others carefully and see where it gets you. Are you on an aftermarket bumper?
If memory suits me well, these are pressed in studs from the back side of the flange. When brining mine back to life after a front end hit, I ended up spinning one of these loose, we just tacked it solid while welding in the radiator support.
If you can get the others off you should be able to just beat the broken stud out and replace it with an appropriate sized bolt/nut.
aemravan is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 10:28 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
When there's rust or heavy paint on the threads and you try to remove a nut the rust or paint gets jammed into the threads between the nut and stud causing the nut to jam, try removing the rust and or paint off the threads first with a wire brush or wire wheel in a drill, and then when removing the nut back it off and if it binds or gets tight, tighten it a bit and hit it with the wire brush again to remove any debris jamming it up, rinse and repeat until you get all the nuts off.
A little bit of heat from a propane torch may also help in conjunction with the above mentioned wire brushing in getting the nuts removed.
2004 Limited V8
bolt , bolts , bumper , install , side
2015 TRD Pro - Broke front spring? (broke while parked in garage) rustbeltboss 5th gen T4Rs 20 02-24-2021 11:53 AM
Front skid bolts broke brown dog 5th gen T4Rs 12 08-20-2019 05:07 PM
Stripped screws and broke bolts AZ3rdGenRunner 3rd gen T4Rs 10 07-14-2014 09:06 AM
Question on bolts for ARB bumper install jsmithjr732 3rd gen T4Rs 7 12-12-2010 09:22 PM
