Old 03-25-2021, 11:56 AM #1
thmclaugh thmclaugh is offline
thmclaugh is on a distinguished road
Help Identifying Weird Clicking/Ticking Noise
Good morning everyone,
My 2006 V8 Sport Edition (120k miles) is making a slightly odd clicking/ticking noise at lower speeds, and wanted to see if anyone may be able to identify the culprit. I am including a link to a recording here: Car Noise by thmclaugh | Free Listening on SoundCloud
Some information on work done recently:
- Replace old XREAS with Bilstein 5100s, OME 895 coils in back, new SPC UCAs and new OEM LCAs, diff drop kit
- Replace timing belt and water pump
- Replace stock tires with 285x70x17 Falken wildpeaks (also BMC to fit these)
- Split transfer case to fix actuator seal that was leaking oil (ugh)
- Install Sherpa Princeton roof rack
I am a relatively newer owner, only had the truck about 5 months so maybe this noise is normal? But it seems a bit suspect. Hopefully you guys can hear it on that recording. Here is a little info on the noise as well:
This noise speeds up as the tires rotate faster, and is heard at lower speeds 25mph or less. Sounds like it is coming from the front end of the truck/maybe engine bay or around there? It seems to be the loudest after starting the car up, and fades away basically entirely after driving for a bit then returning to lower speed. Also, no noise is heard in reverse at lower speeds or when not moving.
thmclaugh is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 02:08 PM #2
To follow up on this, does anyone think this noise could be a cracked exhaust manifold?
Old 03-25-2021, 04:30 PM #3
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
I had a manifold crack, it is not that. Where did you take the recording from, inside the cabin?
To me it sounds like a contact rattle. If you say it is proportional to wheel speed then it is definitely something interfering. Typically brake components or parts in the wheel assembly make more of a grinding noise.
If you just did your belts and pump then it is likely something with the fan/shroud rubbing slightly.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 04:48 PM #4
Yeah, that recording is from inside the cabin in the driver's seat. That would make sense on the fan/shroud..I will look into that!
Old 03-25-2021, 04:58 PM #5
spartacus's Avatar
spartacus's Avatar
Go underneath the car and see if the noise gets louder or seems to be coming from the bell housing which could indicate a cracked flex plate. full disclosure, I don't have a 4th gen but similar sound is indicative of a cracked flex plate in 3rd gens.
Old 03-25-2021, 05:01 PM #6
MikeinNH67's Avatar
MikeinNH67's Avatar
Hard to tell, bring it into a parking garage that has walls and try to pin point it while moving.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
bit , lower , noise , replace , speeds
Weird metal tapping/clicking noise from engine zzzzzzz7zzzzzzz 3rd gen T4Rs 3 01-20-2019 03:52 PM
Reverse to Drive weird clicking noise webbbj 4th Gen T4Rs 6 04-11-2015 08:29 PM
clicking or slight ticking noise 3.4 liljoe113 3rd gen T4Rs 1 08-25-2013 09:15 PM
Clicking/Ticking noise from the engine GuardianBU 4th Gen T4Rs 6 02-21-2007 11:51 PM
Clicking / ticking / clanking noise in engine - 2004 V6 PolkManiac Problems & Warranty Issues 2 12-17-2006 04:37 PM
