Old 03-26-2021, 12:35 PM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Should I replace the steering rack?
I need new inner tie rods and boots. Should I just go ahead and replace the steering rack? Steering has always been heavy, but I have no idea if there is actually a steering rack problem...
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 12:51 PM #2
montijo505's Avatar
montijo505's Avatar
Unless it leaks or needs bushings, I’d leave it be. Have someone turn the wheel while you watch the rack, if it shifts the bushings are done. The bushings, if memory serves, are a pain. Easier to buy a rebuilt rack and replace. CVJ sells them remanned, if you want new buy from McGeorge online, best prices around.
Old 03-26-2021, 01:35 PM #3
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Its probably the intermediate shaft u-joint
Steering Column U-Joint
On mine, I added 1oz of AT205 to recondition the rack seals.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 03:23 PM #4
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Make sure it IS indeed the inners and not the rack bushings...they display in a similar manner when shaking a tire back and forth. Have someone else work the tire back and fort and get your hand on the joint. If the whole thing is going up and down its more likely the bushing... you should be able to tell fairly easily.
If its the Inner tie rods IMO just replace those.
If it's the bushings in the rack do the rack.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 03:51 PM #5
Ok, so let me make sure I understand. Put my hand on the inner tie rod joint (which is under the rack and pinion boot), and have someone turn the steering back and forth. If its the tie rod, it will just be sloppy. If it is the rack bushings the whole rack will move up and down as the wheels are turned?
Old 03-26-2021, 04:01 PM #6
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Leave it if it's not giving out serious issues. Maybe change the power steering fluid for lighter steering? I would only change the rack if it's obvious that it won't be saveable.
2000 4Runner Limited 4x4 V6
Old 03-26-2021, 04:36 PM #7
Warwicke36's Avatar
Warwicke36's Avatar
The easiest way to tell is to pull the inner tienrod boit off at the rack and watch as some one shakes a wheel back and forth (at the wheel not steering wheel)... If its the rack bushings you can see the rack part of the rack move up and down where it goes into the rack body. You can feel for this through the boot too. If its the inner joint you can feel it AT the joint but the rack (inner part hidden beneath the boot, not the outer body) shouldn't have movenent. Does that make sense? Its hard to describe via text. I am not a great technical writer, esp on my phone.
2004 Sport 4.0
Old 03-26-2021, 06:20 PM #8
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Jah; heavy steering can be caused by old fluid.
My '15 with 65k miles was very heavy until I changed; it was surprising how much lighter the steering was after a couple of drain & fills.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 07:10 PM #9
Imgur: The magic of the Internet
Any opinions on if this is too much play up and down?There is possibly a little play up and down, definitely the joint is shot.
The boot had a bunch of fluid in it, though none of it looked like PS fluid. More looked like the Grease from the failed joint combined with water...
Old 03-26-2021, 08:23 PM #10
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
First, that video looked perverted There should be no liquid inside that boot unless the boot is split and you possibly drove through or splashed water into it. Anything else would be PS fluid and the only way it would be there is failed seals. I really can't tell from the video how much up and down movement there is but if you had liquid in the boot my vote goes for replacing the rack.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 09:02 PM #11
Warwicke36's Avatar
Warwicke36's Avatar
Based on the video I say do the rack. I have had a few beers but I see movement in the bushings.
Also you can grab the exposed rack ans move it up and down and check for any play. If it clunks at all ita shot and will only get worse rather quickly
2004 Sport 4.0
Old 03-26-2021, 10:03 PM #12
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
How many miles are on this? Kind of curious what the life span is on these steering racks.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 10:28 PM #13
180k miles
Old 03-26-2021, 10:29 PM #14
The boot was split, complicating the issue -_-
Looks like I may be ordering from the rack doctor.
Old 03-26-2021, 10:46 PM #15
Thanks to everyone for opinions. I'm stumped on this one. The shaft isn't moving when I hoss on it directly, but the boot was full of stuff.
I'm really gunshy right now, because since January 1 I have replaced PS pump, alternator, valve cover gasket, UCA, LCA, sway bar end link, pcv valve, and an ABS wire... So this car is trying to get away from me. Makes me see ghosts in places they might or might not be.
heavy , idea , rack , replace , steering
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
Replace steering rack? silver4est 3rd gen T4Rs 12 12-10-2018 03:01 PM
Replace ITRs or replace steering rack. johnbyebye 3rd gen T4Rs 8 09-15-2017 08:09 PM
steering rack replace? stinkypoop 3rd gen T4Rs 0 05-05-2016 08:29 AM
what will happen if I don't replace my steering rack duffbeer911 3rd gen T4Rs 5 02-13-2013 02:57 PM
