Old 03-28-2021, 02:31 PM #1
Runnin on E Runnin on E is offline
Runnin on E is on a distinguished road
E-locker 8.2 Install Looking for EWD
Howdy do, new to this forum with a 2008 Sport V8. I have been a member of the FJ forum since 08 (2007 FJ). Anyhoo, I just put an 8.2 E-locker into the 4R and Ima lookin for an electrical wiring manual for a 2009 V8 4R as I believe the E-locker was a one year option then (with All Wheel Drive). Please feel free to correct the the noob at any time....I searched threads here for activating the e-locker and saw that on a 2006 V6 someone used a stock 4WD computer to add it to there's, so I'm looking to do the same thing,thanks in advance. Can't attach pictures from my tablet for some reason......
Runnin on E is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 03:13 PM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
My understanding is that due to economic downturn, there were no v8 4runners made in 2009. This was a point of discussion elsewhere on this forum where the 2009 trail edition was talked about, which was the one trim package that came for the 4th gen with an e-locker.
Also, pretty sure our rear differentials are 8", though I may be wrong on that. I thought the 5th gens got the bigger diff
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 03:21 PM #3
Ok, then I guess I'm looking for a wiring diagram manual for a 2008. So does this mean that my 2008 just got REALLY RARE because it's the last "official" 4gen? Wow, it probably just doubled in value.....
Old 03-28-2021, 03:33 PM #4
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
So if you are looking for an e-locker diagram, it's going to be 2009 v6, because that was the only year it was available. Was never available in v8. Not sure that will help, you could always look around the LC forums since those vehicles actually ran v8s with lockers
Old 03-28-2021, 03:48 PM #5
2008 wdm
Ok anybody got the 2008 WDM? Anybody.......Bueller.....Bueller....
Old 03-28-2021, 03:53 PM #6
I installed an 8.2 in my 4R from a 2013 FJ.
Old 03-28-2021, 06:29 PM #7
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Not sure if you're really going to be able to do that with a V8 for a couple reasons:
-The wiring for the circuit may not even exist on the V8 4Runner (see the attached parts location, connector F15)
-You may need an entire "4WD Control ECU (Rear Differential) Lock" module (see attached EWD Schematic for Rear Diff Lock Circuit)
-IF you did manage to get all the required parts, switches, and connectors, you'd still probably have to run your own wiring for certain aspects such as the Speed Signal, Communication with the ABS/VSC/TRAC module, Communication with the 4WD ECU, etc. (See attached EWD Schematic) Additionally there's no guarantee that these modules will have the programming (these are modules Toyota doesn't have a process for reprogramming that I am aware of) to properly communicate with the new module you install.
There's really three ways I can see this being done effectively and I'll list them in what I thing is the order of easiest to hardest:
1.) Install the locker and make your own wiring circuit, sans module, for engaging/disengaging the locker by mimicking the factory set-up as best as possible.
2.) Try to install a V6 Rear Diff Lock Module in the factory location and run whatever extra wires and connectors you need to make it function. (assuming the computer programming exists to communicate with it, which I am not sure honestly if it will.)
3.) Install an entire V6 4WD Module, Rear Differential Lock Module, and then wire a dummy plug to trick the system into thinking an ADD exists and is functioning when it doesn't and somehow locking out the 2WD option so as not to damage the actuator (I'm not even going to bother theorizing how how you'd do that because honestly, as OCD as I am about trying to make things look/function like it was factory installed this is a ridiculous amount of work.)
E-locker 8.2 Install Looking for EWD-parts-location-jpg
E-locker 8.2 Install Looking for EWD-09-rear-diff-lock-ewd-jpg
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 11:41 PM #8
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
@Drift Monkey may have wiring information. Hes got the 8.2 elocker in his later v8
y=mx+b is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 07:38 PM #9
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
E-LOCKER FULL KIT SWITCH & CABLE - 12 Volt Guy
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 02:05 AM #10
Originally Posted by Drift Monkey View Post
That'd be the option I'd go with, particularly since someone did the work for you and you don't need a module.
Old 04-01-2021, 11:45 PM #11
8.2 Install
Thanks everybody for the input. Yeah, I think the 12volt guy kit is exactly what I need.
activating , e-locker , forum , stock , time
Spartan Locker Install Backwoods Rambler 4th Gen T4Rs 0 08-13-2018 11:04 AM
ARB Locker install Sworkscrux Off-Roading 4 06-15-2018 03:58 PM
Aussie Locker install on 99 2WD SR5 octanejunkie 3rd gen T4Rs 37 11-19-2017 01:56 PM
E-Locker Install Hurdle... Webbuff 3rd gen T4Rs 6 03-09-2016 07:46 PM
where to install an air locker? gonzo Off-Roading 15 06-12-2007 12:06 AM
