Old 03-30-2021, 02:49 PM #1
Sithrebel15 Sithrebel15 is offline
Sithrebel15 is on a distinguished road
Maintance for used '05 with 170k
I just bought a used '05 and it's had basically no preventative maintenance done. I plan on doing the spark plugs, diff oil, and transmission fluid. Anything else I should take care of?
Sithrebel15 is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 04:28 PM #2
Adeadwallnut Adeadwallnut is offline
Adeadwallnut is on a distinguished road
V8 or V6
If v8 timing belt and water pump shortly. In either case you should also change the power steering fluid.
Adeadwallnut is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 05:22 PM #3
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Flushes on brake fluid, coolant, power steering fluid, transfer case, and front diff. Hit your driveline zerks with some grease.
Depending on your longer term plans, you may want to check a few things on your suspension as well.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 07:33 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Check out these threads for some good service ideas.
Should I Service Anything Specific? (High Mileage Purchase)
4th Gen High Mileage Maintenance
2008 SR5 140,000 Mile Service Overhaul? - Toyota 4Runner Forum - Largest 4Runner Forum
150k+ mi 4th Gen 4Runner maintenance - Toyota 4Runner Forum - Largest 4Runner Forum
180k Interval Service? - Toyota 4Runner Forum - Largest 4Runner Forum
Anything I'm forgetting? Preventative maintenance at 200k miles...
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 05:30 PM #5
delucat2 delucat2 is offline
delucat2 is on a distinguished road
bought with 165000 now 230,000
v8 - Start with the timing belt. If you don't know it is good, youre playing with fire.
Grouping tasks that are in the same area helps.
Brakes and Fluids: diffs and transfer, lube driveshafts, grease all zerks, rotors and pads (I did these first - if you can't stop the rest is immaterial)
cheap and easy plus you get a good look at any rust
Front of engine - timing belt kit, drive bellt tensioner kit, thermostat and re-seal housing, replace hoses, coolant and radiator.
After that - pick an area
Top of engine - valve cover gaskets, spark plugs, plug seals, PCV valve, clean throttle body
Suspension: I did upper ball joints, aftermarket new LCAs with bushings, swaybar bushings, tierod ends, installed rear airbags (i tow), shocks (XRES removed)
Assuming you don't discover any major issues, you will have gotten a great look at the drivetrain and suspension. You can make any decision about fancying it up at that point.
delucat2 is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 09:25 PM #6
jlaw904 jlaw904 is offline
jlaw904 is on a distinguished road
I got a 2WD V6 with similar mileage. So far I've:
  • Replaced air filter, removed HCF filter
  • Replaced PCV valve
  • Changed differential fluid
  • Replaced sticking calipers, new rotors and pads, flushed brake fluid
  • Replaced broken sway bar links
  • Greased ball joints
  • Replaced spark plugs
  • Power steering fluid flush
  • Replaced leaking valve cover gaskets
  • Cleaned throttle body and MAF sensor
  • A couple Seafoam gas treatements and an intake treatment
  • Serviced transmission fluid ~5.5 qts and replaced transmission filter
  • Replaced all coolant
On top of regular oil changes of course. Got a couple samples looked at from Blackstone to gauge the engine condition and waiting for the last one for the transmission fluid. At this point, I feel like it's in super healthy shape. I've learned a lot about maintenance this past year.
jlaw904 is offline   Reply With QuoteReply With Quote
diff , maintance , oil , plugs , spark
little maintance kolelt 3rd gen T4Rs 1 07-11-2014 04:55 AM
New to me 4runner maintance NoMoreJeep 4th Gen T4Rs 5 09-26-2012 06:32 AM
Maintance... michael321 3rd gen T4Rs 10 11-07-2010 03:30 PM
Scheduled Maintance FoozGrind 4th Gen T4Rs 1 06-17-2009 07:45 PM
Maintance Manuals AlmightyMoonPie Maintenance/Detailing 15 08-14-2004 08:44 PM
