Old 04-01-2021, 04:28 PM #16
MikeinNH67 has a spectacular aura about MikeinNH67 has a spectacular aura about MikeinNH67 has a spectacular aura about
Originally Posted by gimlithepirate View Post
I think that was more a general statement because I am worried about getting the steering shaft off because of my experience changing out the LCAs. While the balljoint attaches to those bolts, getting it off that bar is a bear. I had to use a pitman arm puller and an impact to separate them when I changed out my LCA.
Also, I'm going to have to separate tie rods because I am ultimately changing out the whole rack, not just the steering shaft. It's just since I have to disconnect the steering shaft anyway to change out the rack, it makes sense to replace it.
Ah, I see. If changing the rack and replacing the shaft at the same time I think I'd just cut it close to the steering rack to make it easier. The troublesome part is moving 2 corroded joints on their spines with one moving up the shaft steering wheel side. Cut it and you only deal with one at a time and both coming off. If you have little corrosion, unlike in this area, then may not be an issue. Good luck!
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 04-02-2021, 09:42 AM #17
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
Smile
Walmart has two brands of Hammer Drills, one is their own brand the Hyper Tough and the other is the Hart both are 1/2 inch and for their low price will do what is needed. the Hart is around $15 dollars higher then the Hyper tough.
If you don't think they do your job you just return it to Walmart get a refund.
Ralph Blake is offline   Reply With QuoteReply With Quote
drill , electric , hammer , lucky , work
Intermediate Steering Shaft Replacement - fixed steering clunk! Lamer 3rd gen T4Rs 6 01-20-2021 10:38 PM
Need help removing steering shaft off steering rack TheCremePuff 4th Gen T4Rs 4 10-07-2017 11:57 PM
Removing the center shaft of the CV axle and driving without it zz_denis 3rd gen T4Rs 9 08-24-2017 09:56 AM
Drill bit recommendation to drill out and tap 8mm skid plate bolts to 10mm 07V8 4th Gen T4Rs 10 01-12-2017 11:20 PM
Quick PLEASE help on removing 2wd Drive Shaft YearZero 4th Gen T4Rs 3 02-28-2015 02:51 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
