Old 04-01-2021, 11:20 AM #1
indoyota indoyota is offline
indoyota is on a distinguished road
2wd spindles the same as 4wd spindles?
Title pretty much is my question. I can't find a straight answer to whether i can use a spindle that came off a 2wd 4runner and use it on my 4wd 4runner. Can i do this?
2007 4runner, OME rear 3 inch springs, All pro UCAs, Dobinsons coil-overs at 3 inches. 285/70r17 Falken ATs.
semper fidelis
indoyota is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 11:30 AM #2
montijo505's Avatar
montijo505's Avatar
Old 04-01-2021, 11:37 AM #3
Originally Posted by montijo505 View Post
Damn, how do you do that? And on a phone, too. I need to re-think my life. lol.
semper fidelis
Old 04-01-2021, 01:18 PM #4
montijo505's Avatar
montijo505's Avatar
Just Google McGeorge Toyota, enter vehicle info and use keyword as a search. In this case knuckle.
Old 04-13-2021, 08:41 AM #5
hetzler_l33's Avatar
hetzler_l33 hetzler_l33 is offline
hetzler_l33 is on a distinguished road
Originally Posted by amelbeabk View Post
I have a rwd f150 2005, also a f150 2006 FX4. The front rotors are crazy expensive for the rwd. The ball joints, tie rod ends all are the same for both. Would it be possible to swap the FX4 spindle assembly onto the RWD truck? The FX4 is being parted Tutuapp 9Apps Showbox out.
The rotors are not interchangeable. The 2wd rotors have the front hub bearings built into the rotors, hence the huge price difference. The 4wd f150 uses the CV axle but to set the hub bearing torque.
The 2wds are a normal axle but torqued to set the hub bearing. If you swap the spindles, you wouldn’t have anything to set the front hub bearing torque correctly without the CV axles which a 2wd won’t have.
hetzler_l33 is offline   Reply With QuoteReply With Quote
2wd , 4runner , 4wd , spindle , spindles
FS: 4th gen OEM spindles chengitis For Sale: Suspension/Wheels/Tires 2 06-01-2020 12:05 AM
4th gen spindles in 3rd gen 01thunder 3rd gen T4Rs 11 06-07-2018 11:00 AM
Spindles: 2wd vs. 4wd MStudt 3rd gen T4Rs 20 12-01-2017 03:34 PM
2wd spindles on a 4wd?? budrico Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-02-2014 08:31 AM
ADD spindles Whackmaster Classifieds - buy & sell (no commercial ads please) 0 03-30-2011 10:54 PM
