Old 04-04-2021, 10:26 PM #1
Rancho5 Rancho5 is offline
Rancho5 is on a distinguished road
3rd Gen guy looking at a 2004 tomorrow. Advice appreciated.
Iím coming from the world of 3rd Gens, specifically at 2002 sport, which I just recently sold to my son. Anyway, Iím going to look at a 2004 SR5 V8 4 x 4 tomorrow, with 150,000 on the clock. Iíll take a flashlight and crawl underneath and inspect for rust, sagging springs, basic leaks and stains, and may take my scanner with me.
As Iíve been scanning the forum I noticed something about secondary air pressure pump and Toyota not being willing to replace it? Is this something that I should worry about and if so how do I check it? Or is it something with the later V8ís with the VVT?
I also read that apparently there is not a transmission dipstick? How in the world do I check the transmission fluid if thereís no dipstick? And, how do I replace the fluid once I get it, just to start out fresh?
In short, any advice you could give me would be appreciated.
02 Thundercloud Sport, 155k.
Rancho5 is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 10:42 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
ads2539 has a spectacular aura about ads2539 has a spectacular aura about
ads2539's Avatar
Listen for cracked exhaust manifolds, a common issue with the V8. Before the engine is warmed up, you can hear a fairly loud ticking sound under the hood. After I replaced my cracked manifolds, I thought I was driving a brand new vehicle.
Iím not aware of the secondary air pressure pump issue, and I have never changed my ATF myself.
2004 Limited 4WD 180k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 12:12 AM #3
BostonJon BostonJon is offline
BostonJon will become famous soon enough
The secondary air injection system is a problem on the Toyota 2uz-fe V8. If itís not currently failed or failing, a bypass can be purchased and installed for $50 and about an hour of your time so I wouldnít let that scare you unless there are current codes indicating the system is failing.
Exchanging the fluid in the trans pan is relatively straight forward. You can also do a more robust fluid exchange using the trans cooler lines. Neither approach requires you to drop the pan unless you wanted to change the filter.
BostonJon is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 12:31 AM #4
Wonderful. Thanks!
Old 04-05-2021, 12:33 AM #5
Excellent, thanks. Good to know thereís a bypass. Too bad thereís no dipstick tho, Iíd still like to check the fluid.
Old 04-05-2021, 06:28 AM #6
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
You don't have to worry about the air injection pump on a 2004 V8, only the variable timing engines have that pump.
2004 Limited V8
Old 04-05-2021, 10:17 AM #7
montijo505's Avatar
montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of
montijo505's Avatar
Am I crazy or did the early 4th gen V8 have a tranny dipstick? I could swear Iíve read on here they do.
Also, the timing belt/water pump need replacing every 90k on the V8. Look for a sticker on the timing cover or under the hood anywhere indicating itís been done. If not use that for leverage as it generally costs about 1k to have done depending on your area.
'08 4runner SR5 4x4 natural white
Toytec Ultimate Lift/ Toytec 1Ē Bodylift/ Stealth Custom Series Ray 10ís matte gunmetal 17x9 -38 offset/ Falken Wildpeak AT3W's 285/70/17/ K&N CAI/ Auxbeam LED headlights/ blacked out headlights/FlowMaster 50 Series/black MBRP tip routed to passenger side/Satoshi mod/ Coastal Offroad front bumper and skids
Old 04-05-2021, 10:30 AM #8
Derekv Derekv is offline
Derekv is on a distinguished road
I have a 2004 V8 Sport. Here is my list;
Check is it has the XREAS suspension or not. If it does, that is the original suspension. I understand they tend to leak.
It is common for the lower control arm bolts to be frozen. I donít think a visual inspection would be enough to tell. I replaced mine so the shop could get the alignment correct.
The boots on the sway bar links.
Timing belt replacement history.
Check if the drive shafts have been greased.
Cabin air filter.
I donít know how to check, but frozen brake calipers are an issue. Mine were.
Derek V
Derekv is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 12:28 PM #9
dcraddo03's Avatar
dcraddo03 dcraddo03 is offline
Real Name: Daniel
dcraddo03 is on a distinguished road
dcraddo03's Avatar
Real Name: Daniel
There is an overflow plug on the drain pan. Takes an Allen wrench although I'm not sure which size. The fluid should barely trickle out of the overflow plug (at operating temp, fluid expands so temperature is important) when it's at the correct level. Although it's a pain without a dipstick, I'd follow this guide. If no fluid comes out at all, there is a 24mm fill plug that you can pump fluid into. Some say you can gravity fill it but I've never had any luck with that so I use a small hand pump.
2006 Sport Edition V8 RWD - Sony XAV-AX100; Rockford Fosgate 10" Punch Sub; Bilstein 5100 / Moog FJ Lift; Stock wheels (powder coated matte black); Chrome Delete; Oracle Halo Kit; Magnaflow Catback Exhaust; Satoshi Grille Mod; BF Goodrich KO2 AT's (275/70/17) - 261xxx miles
dcraddo03 is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 06:42 PM #10
Real Name: Skip
Real Name: Skip
The 2003 V8 did get a 5 speed transmission but it's a non-sealed transmission so it does have a dipstick and uses the same fluid as the older 4 speed transmission, T-IV fluid, both the 2003 and 2004 V6 engines had the older 4 speed transmission, which also has a dipstick and uses T-IV fluid, the 2004 V8 has the sealed 5 speed transmission and 2005 and onwards both the V6s and V8s has the sealed 5 speed transmission, the sealed 5 speed transmission uses WS fluid.
2004 Limited V8
Old 04-06-2021, 01:19 PM #11
Well, after three requests to send the VIN so I could get a carfax, heís stopped responding to my texts. ďWhen I get homeĒ, ďIíll do it right nowĒ, and then nothing. Maybe thatís a good sign.
Old 04-07-2021, 11:18 PM #12
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough
Hey there, I've had two 3rd gen V6 4WDs and now an 08 V8 Limited 4WD.
I will say I absolutely loved my 3rd gens and I wish I didn't sell my 97, but the 4th gen is a big improvement in nearly every way.
My 4th gen rides much smoother, is bigger, has many more creature comforts. I believe the seats are more comfortable and the leather seems to be of higher quality.
The biggest difference is the v8. Man, no more lack of power! It is night and day difference in power and silky smoothness. I found that real world, no lift, completely stock on Michelin defenders I get 15.5 mpg. My commute every day is on the toll road going 72-75. If I drive at 68 mph I'll get 19 mpg. Honestly that is the same mileage as the 3rd gens in my experience.
Things I don't like is I wish I had a mechanical 4wd shifter instead of electronic. Even that can be swapped for a fj shifter. My exhaust manifold is cracked, just part of owning a 4th gen. It is just an annoyance, doesn't really cause performance issues. I did install the saip bypass slyfox kit, but I have the vvti engine so you shouldn't have to worry about it. Luckily my truck has minimal surface rust that I had to grind down and cosmoline over. Sadly this is a very prevalent problem so check that carefully.
Ask any questions you may have.
Sent from my Mi MIX 2S using Tapatalk
TejasRunner01 is offline   Reply With QuoteReply With Quote
3rd , check , dipstick , replace , transmission
Advice appreciated rckeat 3rd gen T4Rs 25 07-13-2018 02:12 PM
Suspension - leveling ----advice appreciated nosamk 5th gen T4Rs 22 12-12-2013 10:24 PM
Rookie needs some advice!! (Greatly Appreciated) 4runnin4ever Classic T4Rs 13 08-24-2013 05:30 PM
new 91 sr5 owner any advice would be greatly appreciated brownbear114 New Members 0 05-19-2013 10:12 PM
n00b question -- advice appreciated Hamburglar 3rd gen T4Rs 14 11-08-2007 05:56 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
