Old 04-05-2021, 12:01 PM #1
Berty_K's Avatar
Berty_K Berty_K is online now
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
PSA: Maintain your battery terminals
Sharing a maintenance item some may have overlooked (I sure did).
I've spent some time building out my 12v setup. I'll share an observation:
  • With stock terminals, I noticed my alternator charging voltage was fluctuating from 13.3-13.9.
  • With new mil spec terminals (pictured below), my charging voltage holds steady at 13.8-13.9.
My old battery terminals were old and corroded-- I suspect this was causing a poor connection the the battery. I didn't do a full "big 3" upgrade because the Mil Spec terminals gave me flexibility to wire directly to the battery.
You probably don't need to go as far as I did. I assume even a proper cleaning would have made a difference.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is online now   Reply With QuoteReply With Quote
Old 04-06-2021, 10:54 AM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Use a brush to get rid of corrosion.
Then put vaseline on the terminals.
Regarding your setup. Blue Sea is made by Eaton. You can buy the Eaton RTMR and it's 100% waterproof / submersible. Waytekwire sells their switchable circuit breakers real cheap.
The only criticism I can give on your picture is the need for rubber boots over your hot terminals. Don't take the risk of anything arcing when you accidentally lay a wrench in there.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 01:46 PM #3
Berty_K's Avatar
Berty_K's Avatar
You’re totally right.
These covers off Amazon just came in today. Both terminals are covered now.
Fastronix Military Spec Battery Terminal Covers (Red and Black) Amazon.com: Fastronix Military Spec Battery Terminal Covers (Red and Black): Automotive
battery , mil , spec , terminals , voltage
Too Many Wiring Terminals on Battery Bad? Chilow 5th gen T4Rs 10 07-29-2020 01:26 PM
No Electricity, New battery, new terminals :( WarpzoneQc 3rd gen T4Rs 8 04-13-2016 08:51 AM
Battery cables and terminals GX4SEVEND 3rd gen T4Rs 3 02-12-2013 03:35 PM
Replace battery terminals? NathanOfSeattle 3rd gen T4Rs 20 01-03-2013 06:01 PM
Battery Cables and terminals GX4SEVEND 3rd gen T4Rs 3 08-17-2011 02:16 PM
