Old 04-06-2021, 07:27 PM #1
rwh963 rwh963 is offline
rwh963 will become famous soon enough
Emergency parking brake noise
so, i put my runner up on ramps to check out a few things. i put the e-brake on (first time used in a long time). went out for a drive after, and started to hear thunking noises and could feel resistance. i pulled over, worked the e-brake a couple of times, drove quiet for a short distance, then the issue came back. it has to be the e-brake. anyone encounter this, and any quick fix?
rwh963 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 07:57 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a jewel in the rough rdruss is a jewel in the rough rdruss is a jewel in the rough
rdruss's Avatar
Real Name: Ron
Just happen to be inspecting mine this week, only done pass side so far but when I do it I pull the wheel, caliper and rotor and take a good look. Sounds like you should do the same. My pass side was good, still good pad left and springs were not rusted up (amazing). I sanded the pads a little and the inside of rotor, blew all off with brake cleaner and reassembled.
If the brake assembly is trashed it looks like a job to replace, have to pull the axle(?).
Old 04-07-2021, 08:44 PM #3
meonard meonard is offline
meonard is on a distinguished road
Thereís a real possibility that the parking brake cables are sticking. This happened on my 2011, itís from a rusty climate and they both froze. Had to replace the cables to correct it.
As an aside I would suggest that the PB should not be used as it might not release and could cause a severe overheating problem.
meonard is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 06:31 PM #4
update: issue has backed off, for now. almost certainly from using the e-brake that time. the shoe mechanism must have backed off the rotor hat enough to not
cause the issue. not gonna use the brake again (unless i absolutely have to). if the rears get done, then i'll have them looked at an adjusted, etc.
Old 04-09-2021, 08:50 AM #5
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
I had an issue once that eluded me to the point I removed the whole parking brake. I've since got it resolved and did so only by noticing the issue by accident.
Double check the backside of the hub flange (where the wheel studs pass through). For whatever reason there's a plate riveted onto the backside of the flange. If it's bent or distorted, it has the potential to kick the parking brake shoe during rotation just enough to create issues / noises.
2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
e-brake , put , quiet , short , time
Parking brake noise issue autoxr37 4th Gen T4Rs 14 10-12-2020 07:00 PM
Parking/Emergency brake adjustment help Ph3n0m427 5th gen T4Rs 21 01-13-2020 09:11 PM
Parking Brake / Emergency Brake Question Woz1976-MT 5th gen T4Rs 5 04-21-2018 05:52 PM
Parking brake - loud clacking noise Benjamin Choi 4th Gen T4Rs 5 12-22-2008 01:33 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
