Old 04-06-2021, 09:20 PM #1
jlaw904 jlaw904 is offline
jlaw904 is on a distinguished road
Angry Found rust coming through the paint. I am bummed. Need advice.
I was trying to find the source of these little bubbles on my rear tailgate:
After removing the interior panel, I could find the source. Obviously it has been fixed before:
I saw that and my heart sank. I spent so much time this year getting this 4Runner in perfect shape engine-wise and now I see this. It literally needs no other work done at this point. I saw the weather strip at the rear hatch window was completely disintegrated. I'm assuming that's what caused the issue before and allowed water to leak all down inside and after they fixed it they never replaced the strip so the issue came back or wasn't fixed properly.
Now I'm deciding what to do since I know it will just continue to spread:
- Have a body shop repair the job which I'm guessing will cost a small fortune. What do you think a job like this would cost?
- Chip it all off myself from the inside and smother it in Evaporust gel for a couple days then clean it and spray some rust inhibitor coating and then accept fate from there.
- Use it as an excuse to start looking for a 4WD with less miles lol
What would you do? This thing is in excellent condition otherwise for it's age.
jlaw904 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 09:29 PM #2
eleven14 eleven14 is offline
eleven14 will become famous soon enough eleven14 will become famous soon enough
Personally I'd start checking salvage yards for a replacement tailgate and be done with it. Sucks but at least it's contained to the hatch and you know what caused it.
eleven14 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 09:46 PM #3
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold
Bluesky 07's Avatar
This is unfortunately a well-known issue. Seems Toyota applied the sound deadening material before the corrosion inhibitor, allowing moisture in, under, & around the material to cause rust.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 10:02 PM #4
Well that just sucks. First I've heard of it.
Old 04-06-2021, 10:04 PM #5
mr_skittle mr_skittle is offline
mr_skittle is on a distinguished road
Took the words from my mouth...
We got our 2006 last fall and the dealership had repainted the back gate to cover up this very issue, and it's already back. There are some threads here that give some ideas and some folks went ahead and did the work you have in mind. I think you are on to the main culprit, the weather seal on the rear window. Ours was trashed too. We also have a Rav4 with the same bad weather seal. That crap is not cheap. The 4 rav windows and the rear for the 4runner cost about $300 but it sure beats the alternative. I've also got rust down at the very bottom of the gate where the sheet metal is all folded together. Again, I assume it's a result of water leaking in the bad weather seal. If the rust it's too bad and it can be repaired, that's the route I'd go. A new gate is an option but probably wouldn't be any less work.
I'm in the middle of a big hitch rehab job at the moment but this emerging rust on the gate is next on the hit parade.
mr_skittle is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 10:09 PM #6
Flesh Eater Flesh Eater is offline
Flesh Eater is on a distinguished road
Glad I saw this now. Going to drill and fill mine with Fluid Film.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 10:20 PM #7
I don't think there's any reason to drill though. After removing that panel and pulling the plastic film off, you have a pretty wide open space for spraying a nozzle around. You can betcha ass I'm gonna do that if I repair it myself this weekend though. Also, apparently the sound deadening material needs to come off to properly coat the metal.
Old 04-06-2021, 10:35 PM #8
Syr4RinNC's Avatar
Syr4RinNC has a spectacular aura about Syr4RinNC has a spectacular aura about
Syr4RinNC's Avatar
Id probably find a replacement through a junk yard or used car parts website - they go for about $500.
You could certainly try to repair it. For you outside of the rustbelt, good chance of it holding up
Im less inclined to repair rust as itll just pop up again
2008 SR5 4WD Black. Bilstein 5100, 5th gen coils/ rear springs. 265 70 17 AT for everyday use. Victory Sliders. headunit upgrade. Back up camera install. Expert at replacement rear hatches
Old 04-06-2021, 11:47 PM #9
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
Just an FYI, the outside bottom weather strip is not and never was designed to keep water out, it's impossible to keep all water out on any window that goes up and down even when the weather stripping is new, this is the same on the doors as well, the weather stripping main purpose is to keep leaves and most debris, bugs, etc. out, the hatch and all the doors have drains in the bottom, these drains do get clogged over time from what little debris gets past the weather strip, also if rust gets started it will also clog the drains as it flakes off.
If you ever hear water in the hatch or doors after a heavy rain it's because the drains are clogged and needs to be cleaned or replaced, also you need to vacuum out any debris inside the hatch/doors.
On older vehicles the drains were simply holes in the sheet metal on the bottom of the hatch/doors, most all vehicles now have plastic drain inserts in the holes that allows water to come out but keeps insects out, these inserts can get clogged once too much debris gets inside the hatch/doors.
2004 Limited V8
Old 04-07-2021, 12:02 AM #10
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a name known to all T4R2014 is a name known to all T4R2014 is a name known to all T4R2014 is a name known to all T4R2014 is a name known to all T4R2014 is a name known to all
T4R2014's Avatar
Spray it with Fluid Film and wait until a clean hatch comes up in your color. Not worth stressing over.
Old 04-07-2021, 07:24 AM #11
rwh963 rwh963 is offline
rwh963 will become famous soon enough
this is why i strongly favor flip up strut rear windows. never had rust problems with them.
rwh963 is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 09:46 AM #12
This is a really good point. Think water-resistant vs. waterproof. The weatherstripping on moving windows is resistant. The thick, squishy stuff around the outside edge of the door is waterproof.
I had this problem in my old Subaru outback wagon. Everytime I opened the rear hatch after a rain the water would pour out. I can't count how many times I unplugged the drain holes but, eventually, it would fill up again. Another problem with that car is it leaked in a lot of dust on gravel roads. Therein lied the problem. The gate would get full of dust, then it would rain and I'd have the makings for some Mud Pies inside the liftgate
cost , find , fixed , job , strip
Paint coming off on hood... Stimulant 5th gen T4Rs 16 10-03-2020 10:09 AM
Found Rust on the Sunroof Frame 92879 4th Gen T4Rs 34 02-14-2017 04:52 PM
Found a spot rust likes to form alexchannell 4th Gen T4Rs 16 12-10-2009 07:38 PM
silver bumper trim paint peeling, coming off colo4runner Problems & Warranty Issues 7 05-02-2008 03:58 PM
Argh...I found a really tiny paint ding on my new baby orangeblast22 Maintenance/Detailing 6 07-03-2006 08:37 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
