Old 04-07-2021, 11:41 AM #1
Iron Chef Iron Chef is offline
Iron Chef is on a distinguished road
Understanding V6's 4Hi mode, and V8's always-on 4Hi
The 4Runner is my first 4x4. I'm just trying to wrap my head around the various modes of 4x4, across the various models of the 4Runner.
From my research, as I understand it, the V6's 4Hi mode is EXACTLY the same as the always-on 4Hi of my V8. (Let me know if I'm off on that, or if there's any caveats).
I still have a question then, on what this 4Hi mode actually does, in terms of delivering effective power to each wheel, and comparing 4Hi + Center diff unlocked, vs 4Hi + Center diff locked.
With center diff unlocked, it seems to me that we still have open front & rear diffs, and power will still always go the wheel with the least traction.
  • So even if just one wheel is completely off the ground, it will get 100% of the power (to spin uselessly), and no power will be delivered to any of the other 3 wheels.
  • Is that an accurate assessment?
  • Is this is true, then what's the point of 4Hi with center diff unlocked?
With center diff locked, we get a 50/50 split of power to the front and rear axels. So if one wheel is off the ground, there's still 50% power at the other axel.
My last question is - when I'm driving on gravel or dirt roads, should I just lock the center diff right away? Is there any reason or benefit to NOT locking the center diff if I'm on a loose surface?
2005 Sport V8 4x4
Iron Chef is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 12:40 PM #2
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
The center diff is a Torsen style limited slip differential, not fully open. When unlocked, it still acts as an LSD to direct power to the axle with the most grip.
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
RivMan is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 01:24 PM #3
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
You actually seem to have a pretty good grip of this. The Torsen center diff has a bias ratio, I think 4:1. So, if a wheel starts to slip, 4x the power can be sent to the opposite axle. However, when a wheel is in the air spinning, it effectively has 0 power (oversimplification) so 4 x 0 is still 0. ATRAC however is your friend, because it gives that spinning wheel some small amount of grip, which in turn allows the LSD to work its magic.
4Hi with center unlock is great for driving on roads with ice, or other variable grip situations. It will keep more grip longer than 2WD, but you can still turn. On trails, the advantage of center unlocked is corners. Sometimes, in tight turns on trails, you can end up with the front and rear wheels fighting eachother. This can increase your turning radius, which in some places is more a limiting factor than grip.
This is why the center lock/unlock is so handy. You can lock it when you need it, and leave it undone when you don't. That said, I end up driving with it locked mostly off road because it disables VSC. There is a mod to give "VSC off" its own switch, but I have not done that yet.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 01:45 PM #4
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
The point of 4H unlocked is to provide greater traction than 2H. You'll get 25% engine power to each wheel and they will be less likely to break traction initially. Also, you get to keep VSC, because that is disabled when the CDL is locked. I find 4H unlocked to be extremely useful, especially in winter conditions. On snowy roads RWD 2WD is not fun at all, haha. But 4H with ATRAC does a great job keeping me moving and VSC has saved me several time. The Torsen center LSD does a great job regulating the front to rear demands for the majority of offroading driving conditions I encounter.
As you become more familiar with your 4Runner, you'll learn what vehicle configuration works best for your needs. You might need the CDL more than I do if you're regularly lifting wheels.
techno is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 01:45 PM #5
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Some helpful videos explaining the Toyota 4WD systems:
https://www.youtube.com/watch?v=pN6-gCxI60g
https://www.youtube.com/watch?v=4v2rC8sbkRM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 01:59 PM #6
techno's Avatar
techno's Avatar
When I'm offroad, I am constantly monitoring and judging my traction needs and making changes as needed. Most good condition, dry gravel roads don't even need 4H at all, so I will remain in 2H unless I feel the rear end getting squirelly or I can see an upcoming need for more traction. If I'm driving fast on gravel, 4H is my choice because it helps with steering response and I have more control. I rarely use the CDL for regular dirt/gravel roads. My AT tires keep enough traction to simply not need it. But if you've got shitty highway tires, you might feel the need for it.
Bottom line is, the driver needs to make the choice based on a multitude of variables. There really is no hard rule. (except no CDL on paved dry roads, lol)
Old 04-07-2021, 02:50 PM #7
-Rob
Ahh, so the V6 is a fully open center diff then? (when unlocked)
2005 Sport V8 4x4
Old 04-07-2021, 02:58 PM #8
techno's Avatar
techno's Avatar
No, the V6 is also an LSD center, just like the V8. The V6 just has the extra ability to be in 2wd.
Old 04-07-2021, 03:04 PM #9
Thanks everyone for your responses! Have a much clearer understanding of the subtleties of these modes now. So regarding CDL on or off, it depends on whether I need to prioritize turning response vs grip at any given moment.
2005 Sport V8 4x4
Old 04-07-2021, 11:23 PM #10
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I recall reading somewhere that the power ratio front to rear is 40F/60R due to the shape of the gears on the center torsen diff.
It'll behave a bit more like a RWD in most circumstances.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 06:14 PM #11
venomj venomj is offline
venomj is on a distinguished road
Yeah, that's also what I remember.
venomj is offline   Reply With QuoteReply With Quote
4hi , center , diff , power , wheel
Need help understanding Alignment?? Jon88 3rd gen T4Rs 8 02-04-2019 04:04 PM
Switching from shift mode to drive mode Happy 1 5th gen T4Rs 31 05-12-2017 12:34 PM
2009 Limited V6 Multi Mode 4wd in 2wd mode JCSTEW 4th Gen T4Rs 2 09-11-2015 07:52 PM
Help with LBJ understanding Suprareal 3rd gen T4Rs 8 08-12-2012 12:37 AM
A little help understanding 4wd Muti007 3rd gen T4Rs 54 05-27-2010 10:42 PM
