Old 04-08-2021, 07:55 AM #1
blkexp98 blkexp98 is offline
blkexp98 is on a distinguished road
Stock FM/AM Antenna Reception
I'll preface this by saying I have read through the previous posts I've found on this topic.
So I have changed out my stock headunit to a pioneer model and as most know with the aftermarket head units there is only one antenna input. I've also read that the factory antenna amp needs to be powered. I tapped into what I thought was the power wire people were talking about but apparently I'm mistaken as my reception didn't change. Can anyone point out the wire to add power to and mention where you sourced it from?
The threads I read most people said they used the remote turn on wire from the head unit so that what I have currently tried. If all else fails have any of you found a superior aftermarket antenna to install?
Sent from my SM-G975U using Tapatalk
2007 Limited 4Runner
4x4 V8
blkexp98 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 10:11 AM #2
Reading back though this I see I didn't add what wire I attached to. I tried to use the small wire (not the second antenna) that is bundled together with the antenna cables.
4x4 V8
Old 04-08-2021, 12:49 PM #3
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
This is from memory but I also had poor reception even after installing a 2-receptacle adapter so both antenna leads are connected. Called Crutchfield and IIRC, the blue wire must be connected to the blue/white. I don’t think I did that during the install but haven’t had the dash apart yet to check.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 08:58 AM #4
Okay ill open it up and see if I see a blue/white wire. The blue from the head unit should be that remote turn on wire.
4x4 V8
antenna , head , power , read , wire
XM Antenna no reception? EmotionCRZ 5th gen T4Rs 5 01-09-2021 01:42 PM
Diversity antenna- reception fix for aftermarket hu Mafster Engines / Suspension / Wheels / Tires / Audio / Accessories 54 12-05-2018 11:15 PM
Disconnect antenna amp better reception than when connected? Huh? rpm215 4th Gen T4Rs 6 07-31-2018 12:33 AM
Better AM Antenna Reception? spooner 4th Gen T4Rs 1 07-03-2007 04:26 PM
Antenna reception wth Scion Changer Bernie Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-30-2004 12:45 AM
