Originally Posted by CO4x499
Thanks. I can't find the specs for these wheels to check the offset/etc, so I wasn't 100% certain.
Aside from the specs, the caliper size can be an issue as others have explained already. Here are the specs for those 16" wheels.
Btw, I was struggling to find Toyota wheel specs for my 08 too and came across this site which helped.
Autorimshop - 2020 Toyota Tacoma 16in Wheel Specs
Just search for the specific OEM wheel once you select the specific vehicle model.
Regarding offsets, I have used the following website to visual how new tires will fit. Probably overkill in your case but it can be very helpful when going with bigger tires or changing offsets.
Wheel Offset Calculator
I put your current wheel setup and the new setup in there and got the following.
Hope this helps...
