Old 04-10-2021, 08:19 PM #1
SqWADoosh's Avatar
SqWADoosh SqWADoosh is offline
SqWADoosh is on a distinguished road
SqWADoosh's Avatar
Sway Bar Blocking YZZD3 Oil Filter?
So I bought a case of YZZD3 OEM oil filters. However my front sway bar is blocking the filter from going on? Tires are on the ground, what am I missing fellas?
SqWADoosh is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 10:39 PM #2
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Do you have the v6 or the v8? I believe one takes the yzzd1 and one takes the yzzd3. The thread is the same on both, but D1 is a bit shorter than the D3, so you likely need the D1.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 11:24 PM #3
SqWADoosh's Avatar
SqWADoosh's Avatar
I have a V8. This is the V8 filter and Toyota shows it compatible?
Old 04-10-2021, 11:47 PM #4
montijo505's Avatar
montijo505's Avatar
The D3 is for the V6. How much you want for them? Lol
Old 04-11-2021, 03:16 AM #5
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
You could always just remove the sway bar. Filter fits just fine without it and handling is fine too.
I run the YZZD3 on my 03 V8 and don't recall there being a fitment issue with that filter before I removed the sway bar.
Just a thought as well. A little more work but you could also unbolt the sway bar links from the spindles and rotate it out of the way.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 08:29 AM #6
BostonJon BostonJon is offline
BostonJon will become famous soon enough
That definitely looks significantly taller than the standard filter.
I have the V8 and there’s a lot of clearance for the filter so that larger filter would probably work. Didn’t know it was so tight by the filter for the V6
BostonJon is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 10:16 AM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
No question the D3 is for V8 (also fits V6), I have an '03 V8 and only filter I use on it and changing is no problem.
Old 04-11-2021, 12:19 PM #8
montijo505's Avatar
montijo505's Avatar
The V6 actually has the filter near the oil fill neck up top of the engine.
Old 04-11-2021, 04:28 PM #9
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Chances are if you removed the sway bar to get the filter on, the sway bar will likely rotate into the filter... at best putting a dent in it. At worst, splitting it open at the mounting seam.
My ADDCO bars contact the standard sized oil filter, regularly putting a dent in it. I use an even shorter one to ensure it doesn't contact.
I'm not sure what the bend differences are between the OEM and ADDCO bars, but I'd imagine if it's nearly an interference fit at rest, there's a good chance the OEM bar will contact under hard cornering.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 01:24 PM #10
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Who needs a front sway bar anyways. Toss it
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
bar , filter , oil , sway , yzzd3
FS: OEM Toyota Oil Filters YZZD3/YZZZD1 & Prothane Sway Bar Bushing Kit - Seattle, WA markeezy For Sale: T4R Items 0 01-31-2020 02:56 AM
Anyone using Toyota 90915-YZZD3 larger oil filter? BamaDrewski 3rd gen T4Rs 20 05-27-2019 04:25 PM
Please list the cheapest place to get OEM 90915-YZZD3 oil filter TRD04RUNNER 4th Gen T4Rs 22 07-31-2018 11:58 PM
YZZD1 Toyota oil filter...same as YZZD3 ? DarksideSurf Maintenance/Detailing 7 01-14-2017 04:53 PM
