Old 04-12-2021, 05:30 PM #1
Porqupine82's Avatar
Porqupine82 Porqupine82 is offline
Porqupine82 will become famous soon enough
Braking Problems Pt 2
Again attempting to diagnose my braking problem, I have found that with the ignition off, and pumping my brakes 20 times, they build pressure until about the 12th pump getting more solid, then on the 13th pump it goes to the floor.
After turning the key to 'RUN' with the brake still depressed, the accumulator kicks on and makes the brake feel normal again.
Then, after every press of the brake the accumulator runs. I remember at one time the pump only ran every 3 or 4 brake presses. I cannot find any visible leaks in my lines and my fluid level remains normal.
Ideas?
Thanks
Instagram: overland_tennessee
Website: www.redclayrally.com
Porqupine82 is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 05:43 PM #2
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
Air.
Did you bleed them from the farthest to the closest? Sometimes try redoing the pass rear after the driver rear and start over again.
Did the reservoir go empty?
Check all the banjo bolts on the calipers for tightness or wet spots.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 02:41 AM #3
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Ideas?
Thanks
I suspect the infamous problem of the leaking piston of the 4th gen brake system has caught up with you.
Do you hear a slight whooshing sound when ypu engage the brakes?.
Its an internal leak of a piston and oring that is supposed to hold pressure. A member here has done the diy repairs after buying the piston for $55
If you are unable to locate the thread, let me know, will try digging it out later
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 06:50 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Ideas?
Thanks
Other than what has been mentioned so far, I'm thinking your problem could be the accumulator not holding pressure, or the pump not building up that pressure, when your "accumulator" kicks in the noise you're hearing is the electric motor that runs the pump, it should only run for around 5 to 10 seconds, if it's running longer than that then either the accumulator is not holding enough pressure or the pump is not putting out enough pressure, and you're correct that the motor should only kick on about every 3rd depressions of the brake pedal.
2004 Limited V8
accumulator , brake , braking , normal , pump
Braking problems, binding!? Porqupine82 4th Gen T4Rs 2 03-31-2021 07:38 PM
Braking problems spongerx 3rd gen T4Rs 6 06-05-2015 01:39 PM
She pulls to the left when braking harder, but not when normal braking... Goyo 3rd gen T4Rs 6 11-30-2012 08:21 PM
Braking Problems! gmata 3rd gen T4Rs 3 04-21-2012 12:08 PM
Does increase in tire size cause any problems with ABS or other braking systems??? EdinAthens 5th gen T4Rs 2 04-22-2010 08:17 PM
