Old 04-16-2021, 10:26 AM #1
WTS WTS is offline
WTS is on a distinguished road
WTS WTS is offline
2003 xreas control absorber leaking
Hi, My right side xreas control absorber is leaking fluid. I'm just wondering if I can just replace the control absorber and be good to go. Or does it leaking mean it is draining all of the hydraulic fluid from that side of the system.
I understand there are valves that close when the system is taken apart to prevent the fluid from leaking out of the system but what does it mean in the case of the absorber leaking.
Thanks for any insites into this from all of you who have been working on your own xreas systems in the past.
If I remove the xreas system do I have to also replace the rear airbag system that came factory installed and install new rear coils or can I keep it and just install normal shocks in the rear.
WTS is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 03:11 PM #2
AndroT100's Avatar
AndroT100 AndroT100 is offline
AndroT100 is on a distinguished road
AndroT100's Avatar
Hello! I am also dealing with XREAS...just have the fronts seeping a bit.
Toyota will tell you that you have to replace the all the lines and control/pumps. And maybe the coil-overs and shocks. I do not believe the airbags are part of the XREAS system and that they can stay. This written, new coils are inexpensive and you may like them in any case. My local dealer wants $3850 to replace my whole XREAS system and this is with a 38% reduction in the cost of the parts.
2003 4Runner Sport V8 4x4
AndroT100 is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 03:48 PM #3
depends on how bad its leaking, if just seepage then its probably ok to replace just the shock but if its wet or been leaking awhile it probably lost too much fluid & would need serviced by a dealer & as posted above, the price is ridiculous!
most people just remove the xreas & install shocks that meet their needs, if mainly street driven or light off road i suggest & use the KYB shocks, they come complete with front springs & will raise the front about 1" over stock & have an excellent ride. about $100ea at rock auto & $40-50ea for the rears.
you can keep the rear air bags & springs.
Old 04-16-2021, 04:07 PM #4
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Try searching this forum? This has been gone over so many times already. So many options for replacing the crap XREAS without spending a ton of money.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 04:10 PM #5
AndroT100's Avatar
AndroT100's Avatar
How does the handling of the KYB shocks compare to the XREAS? I am at this moment trying to decide which way to go...Bilsteins, KYB, OME, Dobinson, etc.. Really want to keep close to, or improve on, the ride/handling of the XREAS and only want about 1" lift.
Old 04-16-2021, 04:20 PM #6
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Best bet in that case would be to go with the take off 3rd gen Tacoma Bilstien springs and shocks in the front, get new 4Runner Bilstien rears to match (you can use the Tacoma ones but the 4Runner shocks are valved for the heavier vehicle) and 2007 up FJ rear coils. That will give you the 1" or so lift you are looking for and rides great on and of road. And it should be less than $500 in parts.
Old 04-16-2021, 04:31 PM #7
WTS WTS is offline
WTS WTS is offline
Thanks for all the answers guys. Basically I just want to keep it as close to stock as possible. I just want to reuse the factory coils that are on it now. So there seems to be some votes for KYB struts/shocks, now about the bilstien 4600 series or is the 5100 series better for stock handling/feel.
thanks.
Old 04-16-2021, 09:46 PM #8
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
The front left is connected hydraulically to the rear right, and front right to rear left. Follow the lines that come out of the shocks... So, no, if it's weeping, leaking, etc, you should replace them expediently rather than have a full on failure at a terrible time. As far as I can understand, if one corner fails completely, the opposite corner will as well, as that they share hydraulic fluid.
I've not heard of this. My understanding was that the 4x shocks come in two "kits" FR/RL & FL/RR, two pairs of two shocks, and the long hydraulic lines connecting the the shocks together. Intended to be replaced altogether. A tech would lay out both pairs of shocks and then lift it all up into the chassis a piece at a time, avoiding kinking the lines. All discussions I've read about XREAS is that the system cannot be bled.
Yeah, I thought I could keep the RAS system. But in practice, it just didn't work well without the XREAS. The ride height was too low and I kept hitting the bump stops. Pumping up the bags by changing the sensor positions fixed that but then it handled terribly. I got the conversion kit for it and used MOOG OEM springs. Note you'll need to get bump stops from a non-RAS truck. I chose to go with the "super bump" kit... I don't recall who makes it at the moment. But they're amazing, especially if you're not lifting the truck much.
thanks.
Depends on what you refer to as "close to stock handling". The body roll control of the XREAS is very difficult to mimic with mechanical parts. If you're used to how the truck cornered with XREAS, and liked its road holding capabilities, you should prepare yourself for a new vehicle that just isn't like the old one.
"Road holding characteristics" around here is generally what gets to the trail head in one piece... anything more than that is vanity when the truck's got 800lbs of armour & gear, and 33-35" tires.
The ADDCO sway bars are the only option I could find that gets the truck close to how it went around corners with XREAS.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 10:05 PM #9
WTS WTS is offline
WTS WTS is offline
Just on the way home today my right side absorber must have lost all of it's fluid, now I can tell there are no shocks(RR and LF). So I guess it will be the bilstien 4600 shocks/struts sooner than I thought.
Yes I know it's not going to take mountain highways in BC like it did with the xreas but I'll have to take a little more care with the body roll. Yes after driving it for 16+ years it might be different for sure. But I also drive a Lexus RX350 and you probably know how those roll in the corners-nothing like the xreas system that's for sure, ha-ha. I'd like to keep the xreas but not at the costs Toyota would want to fix the one side, then who knows 1 or 2 years later the other side goes. I hope to sell it in a couple of years after I get out to the island(Vancouver Island), then I'll probably buy another Lexus of some sort. Would be nice to get a GX460. Of course their equal of the xreas is no doubt even more expensive it needs fixing.
Interesting that you say yours sat lower in the rear airbags after changing it out. I talked with a couple of shops that specialize in 4runners and I told them I wanted to keep the airbags but dump the xreas and they said they have done lots and they never mentioned any problems with the rear sitting lower. And really I don't see why it should, the air pump should set the level regardless of what shocks are there. Unless you had alignment problems with your leveling system it should work just fine. I know mine still works fine as I lower and raised it from time to time and even sometimes I can hear it releasing air when I shut it down after parking. I guess I'll find out when I change them out though.
Old 04-17-2021, 08:44 AM #10
ght4R ght4R is offline
Real Name: L
ght4R is on a distinguished road
Real Name: L
Just finished swapping out my XREAS with Tacoma TRD fronts and 4Runner specific 4600s. The front shocks had clearly been seeping for years, hard to say if there was any fluid left.
I was driving a Sport Edition that just had the XREAS replaced in June of last year. The Bilstein 4600s feel a little more floaty, but other than sharper corners the ride is comparable and so far I like the ride and stance. For less than $300 I think itÂ’s a great option to swap out the tired, leaking XREAS.
I wouldÂ’ve gone with the 5100s but they were on backorder and I didnÂ’t want to wait until July for the rear shocks to come in.
2004 Sport Edition V8 4WD
ght4R is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 09:14 AM #11
WTS WTS is offline
WTS WTS is offline
Well after just experiencing what no fluid in the RR/LF shock feels like, you would definitely know if there was no fluid in the system. It is like not having a shock in those corners at all, especially when braking it just dives to the front left. I'll be going with the stock coils which are on there and the bilstien 4600s and keep my air bags in the rear with 4600s. Yeah it won't corner the same but oh well.
Old 04-17-2021, 11:11 AM #12
the KYB handle very good IMO, they do everything my non leaking xreas did aside from harder corners, the kyb have a little more body roll but thats expected with a mechanical vs fluid coupled system. the way to improve body roll is using poly sway bar bushings to tighten up the cornering. with teh 10% stiffer springs & shock valving of the kyb & poly sway bar bushings you should be very happy with the corner handling & street driving.
Old 04-17-2021, 11:14 AM #13
WTS WTS is offline
WTS WTS is offline
where did you get the poly bushings from.
Old 04-17-2021, 11:14 AM #14
the xreas system has one way check valves at each shock to prevent fluid from leaking or air from entering when any given shock is removed, they can be changed individually by the dealership or a competent mechanic that knows how to work on the system. they are not intended for bleeding, they re just one way check vales.
Old 04-17-2021, 01:46 PM #15
I too could find no real explanation for why it didn't work just fine. One day I hit a speed bump too fast and hit the bump stops so hard the steel straps that held the bilstein 5160 reservoirs onto the chassis broke off, dropping the shock reservoirs into the rear suspension.
It became clear something had to change, and fast. So I ditched the RAS for standard coils and super bumps. Handles big bumps with grace and dignity now.
2005 V8 Limited
absorber , control , fluid , leaking , system
Leaking Xreas? Mikes3rdgen 4th Gen T4Rs 15 06-20-2020 08:25 PM
FS CA: X-REAS Lines and Center Control Absorber SanDeggo For Sale: T4R Items 1 11-14-2014 12:56 PM
XREAS leaking @35k :( nashman69g 5th gen T4Rs 36 01-12-2014 05:34 PM
Xreas is leaking!!! boozng 4th Gen T4Rs 5 04-22-2009 06:44 PM
Xreas leaking again LeesO4 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 02-02-2009 01:34 AM
