Old 04-27-2021, 11:43 AM #1
PharmSCRunner PharmSCRunner is offline
PharmSCRunner is on a distinguished road
SRS Airbag light
Hey guys, my 06 sport with ~174k miles has the SRS airbag light that comes on intermittently. It's usually on, but will occasionally go off, but then will come back.
I bought the Blue Driver OBDII reader that supposedly could read SRS codes but no luck with that device. Can anyone recommend a scan tool that can read the SRS codes?
I've checked the plugs underneath the seats and all are connected. What's a common cause of the SRS light? Steering wheel clockspring? Any help please thanks!
2006 Black Sport Edition 4WD
PharmSCRunner is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 09:53 AM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is just really nice Bossman is just really nice Bossman is just really nice Bossman is just really nice Bossman is just really nice
Bossman's Avatar
Airbag light on (driver side)
Stuck SRS Airbag Light
UPDATE FIXED* Clock spring replaced problem solved! - Airbag light stuck on
Summer: Michelin Premier LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 10:36 AM #3
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo is on a distinguished road
Buckaroo's Avatar
Bluedriver website says it should read SRS for your vehicle. You need to make sure you are in enhanced mode and you might have to manually enter your VIN or scan the bar coded VIN on the driver side front door frame to make that happen. You want to run the full system scan....
2002 & 2017 XLE Camry
2004 Honda Accord
2005 T4R Limited V6
2010 Mazda MX-5 Touring
2017 Tundra Limited DC 5.7L TRD 4WD
Buckaroo is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 02:27 PM #4
Thanks for the help guys. Turns out it was my clock spring that needed to be replaced. I used a generic OBDII scanner from Amazon for about $15. I used the Fusion OBDII scan app and purchased the 2006 4runner add-on for $10. I was able to read the SRS codes that way. Sure beats having to buy an expensive scanner.
Bought the clock spring on ebay and swapped it in under an hour, using the tutorial linked here. Thanks again
airbag , codes , light , read , srs
Airbag light ON with the key out of the ignitiion... no light when ON. senordan 3rd gen T4Rs 2 09-08-2019 09:30 PM
Airbag light anonymousgromers 4th Gen T4Rs 3 04-06-2019 03:28 PM
Airbag light, ABS light, Slip light, O MY!?! adio3x 5th gen T4Rs 3 09-16-2016 12:25 AM
Airbag light SRS Mick1 5th gen T4Rs 6 07-19-2015 05:09 PM
No airbag light spivey 3rd gen T4Rs 6 04-30-2011 01:24 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
