Old 04-29-2021, 04:11 PM #1
cognus cognus is offline
cognus is on a distinguished road
Lightbulb List of grease points?
Do we have a sticky somewhere that shows/tells ALL available grease points and fittings? Suspension, front end components, driveshaft, differential, other.
Wanting to cover all these bases as a gift to my 07 having now 214k.
cognus is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 08:18 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Are there any other grease fittings on 4th gen
Grease Fittings on 4Runner??
Grease Fittings on '05 4x4
zerk fittings on driveshaft - 08 SportEdition?
Lubrication for underneath - Toyota 4Runner Forum - Largest 4Runner Forum
07 V8 4x4 Zerk Fitting Pics
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 09:09 PM #3
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Grease zerks from the factory:
2wd will have 0
4wds will have 6
  • 1 on each front driveshaft u-joint (2 Total)
  • 1 on the front driveshaft slip joint
  • 1 on each rear driveshaft u-joint (2 Total)
  • 1 on the rear driveshaft slip joint
Optionally
  • Aftermarket LBJs and UBJs may have grease zerks
  • Aftermarket front Sway bar bushings may have grease zerks
  • Aftermarket outer tire rod ends may have grease zerks
  • LCAs or UCAs with polyurethane bushings may have grease zerks, or could be drilled and tapped for zerks
  • Rear trailing arms with polyurethane bushings may have grease zerks, or could be drilled and tapped for zerks
  • Rear Panhard Bars with polyurethane bushings may have grease zerks, or could be drilled and tapped for zerks
Control arms, trailing arms, and panhard bars with factory style rubber bushings won't benefit from grease zerks because the rotation comes from internal torsion in the bushings, and not around a sleeve like with polyurethane bushings
On the topic of lubrication, the replaceable fluids are
  • Engine Oil (5w-30)
  • Coolant (Toyota SLL Pink or any Red/Pink Asian Vehicle coolant)
  • Brake Fluid (DOT 4)
  • Power Steering Fluid (Dexron ATF)
  • Transmission Fluid (Toyota WS or WS Rated Fluid)
  • Front Diff Gear oil (75w-90 or 85w-140)
  • Rear Diff Gear Oil (75w-90 or 85w-140)
  • Transfer Case Gear Oil (Fancy Toyota LF or SAE 75w or 75w-90)
  • Wiper Fluid (if you want to count that lol)
y=mx+b is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 07:30 AM #4
Thanks to you both Bossman & y=.
I thought I recalled the absence of Zerks but want to try to do what I can.
Old 04-30-2021, 08:28 AM #5
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
what about specific types of grease? and will a hand pistol style gun suffice? and how often?
rwh963 is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 08:29 AM #6
2wd will have 0
4wds will have 6
Optionally
thx for the summary!
Old 04-30-2021, 11:41 AM #7
Nickname's Avatar
Nickname Nickname is offline
Nickname is on a distinguished road
Nickname's Avatar
For U-Joints: Lithium base chassis grease NLGI No. 2
For Slide Yoke: Molybdenum disulphide lithium base chassis grease NLGI No. 2
I know a lot of people that use the same grease for both. That being said, the Moly grease will create a film for the slide yokes that is beneficial.
06 Galactic Limited on 33's, Rear locker, Bilstein 5100s, Toytec 2" Superflex Springs, Whitson Metalworks Rack, Squadron Sport Ditch Lights, Dual Viair 450cc Air compressors with 2.5 gal tank, Cobra 75WXST CB Radio
Build Thread:https://www.toyota-4runner.org/4th-g...ld-thread.html
Nickname is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 01:50 PM #8
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Just a note that Toyota TSB EG018-06 advises the use of 5W20 motor oil for various engines from model year 2006 on, including the GR and UZ series that power '06-'09 4Runners. I've used that viscosity for a year plus with no issues.
Bluesky 07 is offline   Reply With QuoteReply With Quote
cover , grease , list , points , wanting
Steering rack polyurethane bushings: grease or no grease? fourfive 3rd gen T4Rs 14 05-07-2017 02:59 PM
List of Lubrication Points on 3rd Gen? BamaDrewski 3rd gen T4Rs 4 03-16-2015 03:28 PM
Where are the lube points on my 3rd gen. and what grease? Benski 3rd gen T4Rs 8 11-09-2012 11:07 AM
Driveline Grease points??? SoCalBurt 5th gen T4Rs 10 10-02-2011 01:05 PM
4-Points NoRaSS411 Off-Roading 7 04-02-2005 02:11 PM
