Old 04-30-2021, 07:22 PM #1
Clarkson! Clarkson! is offline
Real Name: Tristan
Clarkson! is on a distinguished road
Real Name: Tristan
Unhappy Help fitting 255/80 r17s
Hi Everyone, After having put in JBA upper control arms, and redoing the suspension with Bilsten 2.3" springs in the rear, and 5100s up front with what I believe are FJ springs. From what I can tell using a tape measure this has lifted and leveled me a little over 2.25" all the way around. Reading some of the posts I felt optimistic I could get the Cooper ST-MAXXs in 255/80 r17s to fit...I was wrong. At first I thought they fit, then when I was turning the wheel they would bump the front edge of the UCA. As a backup plan I bought spacers. Put those on and am now clear of the UCA but am catching the rear of the fender flare and just grazing the body mount. Im not sure where to go from here. Im considering adding a 1" spacer on the rear and going up to the highest notch on the bilsteins up front which should give me about 3/4" more up front. However, not sure this will solve my problem or is needed. Need some suggestions on what will be the best solution here to get these to fit. Do I need to just find a place to do a body mount chop? Is it possible an alignment tech could push the wheels far enough forward? Im really at my wits end here and tired after 2 days of monkeying with this thing and am open to suggestions. Any help is greatly appreciated!
2005 SR5 4WD: V8 - Doug Thorley headers, Bilstein 5100s, Slee offroad steel brake lines, Tundra brake swap, JBA upper control arms, 33s on RockTrix wheels, etc.
Clarkson! is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 07:32 PM #2
montijo505's Avatar
montijo505's Avatar
Try to get the alignment tech to get as much caster as possible, should move the wheels forward in the wheel well and help. If it doesn’t, get a cab mount chop and trim the plastic.
Old 04-30-2021, 07:55 PM #3
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I have no rubbing with 255/80r17 tires (33.1”) on 5th gen rims (17x7.5) and a full 3” in front, 2” in rear and 1.25” wheel spacers. I also have a 1” body lift, which helps clear the fenders. The full 3” suspension lift in front clears the body mounts. The body lift doesn’t affect the body mount clearance. I haven’t fully compressed the suspension, so I don’t know if there would be rubbing with the wheels stuffed. Daily driving, no rubbing. A pic of my set up is in my signature below.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 08:45 PM #4
SA-Overland SA-Overland is offline
SA-Overland is on a distinguished road
Have you measured the actual tire yet, mounted? Just curious. I have the same rims/tires sitting in my garage.
SA-Overland is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 09:30 PM #5
Real Name: Tristan
Real Name: Tristan
Thanks, will give that a shot and see if we can get clear enough.
Old 04-30-2021, 09:32 PM #6
Real Name: Tristan
Real Name: Tristan
Thanks, sounds like your lift is about where I need to be. Think I will be close to the 3" mark if I bump up one more notch on the front struts.
Old 04-30-2021, 09:33 PM #7
Real Name: Tristan
Real Name: Tristan
Haven't measured the actual tire/wheel yet, will check in the morning and let you know what I find.
Old 04-30-2021, 09:54 PM #8
Cool, thanks!
Old 04-30-2021, 10:30 PM #9
ads2539's Avatar
ads2539's Avatar
I also haven’t measured the tires on my 4R. I do have about 6 months of (covid) use with them. They are definitely taller than my 255/75r17, 265/70r17 and 265/75r16 tires, which are all 32”, give or take 1/10” or so.
I can also measure them tomorrow.
Old 05-01-2021, 10:54 AM #10
ads2539's Avatar
ads2539's Avatar
I just measured the wheels/tires on my 4R.
The four tires mounted and on the vehicle are approx. 32” because of the weight of the vehicle.
The spare, that is mounted and on the roof rack, is the full 33.1” it claims to be, maybe even 0.1” to 0.2” taller in the middle from the 40+ lbs of inflation (E load rating).
Old 05-01-2021, 02:37 PM #11
Real Name: Tristan
Real Name: Tristan
This is essentially what I am measuring as well...just a hair over maybe about 32 and 1\4"
Old 05-01-2021, 04:07 PM #12
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
until you actually off road...you'll be rubbing like a mfer.
to the OP, just get a BMC and call it a day.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 04:51 PM #13
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
255/80r17 Cooper ST Maxx
How to fit 255/80/17 with 2.5 Inch Lift
255/80/17 wit 3.5 inch lift?
Running 255 80r17s? Come on in
Tires to big?
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 05:57 PM #14
ahe242 ahe242 is offline
ahe242 is on a distinguished road
I tried the 255/80/17 Cooper ST Maxx tires with the stock wheels and JBA high caster arms as well. I have a Dobinson's 2.5" front / 1.5" (~) rear lift. Those tires are just too tall for those arms with the stock wheel offset. The 5th Gen wheels with the -15mm offset move the tire outward about an additional .6" inches from the arm and allow for pretty normal turning. There is still plenty of room between the body mount and tire with that set up on mine. You'll want to make sure your caster is close to 4 degrees to get it away from the body mount. My front plastic is also trimmed up, but that's not a big deal.
But I gotta agree that if you can find a place to chop your mounts for a good price, do that with the spacers and you should be happy with it and won't have to worry much about rubbing if you get aggressive. Although, the rears get awful close to the body when stuffed without a body lift.
ahe242 is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 09:22 PM #15
Real Name: Tristan
Real Name: Tristan
Thanks, I think a 1\2" spacer probably would have done the trick....think I will have to budget for some wheels similar to yours in the near future. Have some follow-up calls to make tomorrow on the body mount chop and plan on going through with it to make sure I can get this back off-road without too much rubbing.
fit , front , rear , suggestions , uca
WTB: ARB fitting kit Bellatidusskyebeur Want to Buy/Trade 0 03-19-2017 10:41 PM
Anyone ever use 235/80 r17s Frontline 4th Gen T4Rs 3 11-18-2016 11:45 PM
4th Gen w/ 5th Gen TE wheels 265/70/R17s 2000m2 4th Gen T4Rs 12 12-24-2014 03:05 PM
Looking for pics of 265/70/R17s on 4th gens with no lift zuhl 4th Gen T4Rs 9 03-13-2009 06:21 PM
TRD not fitting on my 05 V8 - Help! voodoodown Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-30-2006 10:52 AM
