Old 05-04-2021, 04:59 AM #16
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
A guy on here (meefzah) did this on a long trip in place of a drain pan: he used a flat-ish box, lined it with a trash bag (two is safer IMO), and drained the oil into that. Then tied up the bag and took it to a recycling center.
thennen is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 05:25 AM #17
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
Must have been quite a pain to drain the trash bags into a storage tank.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 10:36 AM #18
triethylborane triethylborane is offline
triethylborane will become famous soon enough
Puncture the bottom with a knife.
triethylborane is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 07:14 PM #19
3yakabucci3 3yakabucci3 is offline
3yakabucci3 is on a distinguished road
Don't change anything.
Check the level, adjust if oil is needed, and just drive home and do it when you get there.
Engines are NOT as sensitive as our paranoid minds are.
3yakabucci3 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 07:17 PM #20
I thought of that just after I posted it, thought about deleting the post, and decided to leave it as a monument to my lack of imagination.
Old 05-04-2021, 08:09 PM #21
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
Originally Posted by Syr4RinNC View Post
My advice is let it go til you get home. If you’re not starting and stopping with short trips - doing mostly highway driving you’ll be fine. I usually go 7500-10k on mine with synthetic or twice a year. Not worth the headache. Your engine will be fine if you take great care of all the maintenance stuff. You could swap the filter as
Mentioned if worried
my thought also. don't know anything about your vehicle, but i would just keep a few quarts in the vehicle, keep it topped up, and do it at home.
rwh963 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 10:50 PM #22
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Best response in this thread.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 09:04 AM #23
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
This is good advice,
If you want, go to a Walmart buy the correct amount of oil, a drain pan, and a rachet to take out the drain plug.
Next morning drain the oil and refill with new oil. Shouldn't take more than 10 minurtes.
If you can't get underneath the car go to a shop that has a lift.
I have a 4runner. I can do a D/F without a jack.
You can buy a cheap jack at WM, Amazon or any auto parts store - and put it in the trunk.
Amazon.com: BIG RED T820014S Torin Hydraulic Trolley Service/Floor Jack with Blow Mold Carrying Storage Case, 1.5 Ton (3,000 lb) Capacity, Red: Automotive
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 10:19 AM #24
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
@zguy1
So what did you end up doing? I am late to the party and didn't see this until today.
If you're still in the area and want to change, I live about 40 miles from Boulder and my garage is available~~
(that said, I agree with the comment above that you will be fine until you get home… Highway driving is the easiest on your engine's oil and I regularly took my 4R over 10,000 miles)
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 11:13 AM #25
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Originally Posted by JLTD View Post
@zguy1
No worries. It worked out. I was able to change it. Picked up an oil pan from Freight Harbor and got a piece of cardboard and a plastic cup. Had the tools, gloves and rags already.
Got back home a few days ago. Thanks for checking though.
zguy1 is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 07:03 PM #26
Welcome.
Between outfits.
change , don’t , oil , time , wait
Oil change, filter and parts needed? Ripper238 5th gen T4Rs 25 02-26-2022 08:53 PM
Oil Change Gone Bad - Advice Needed on Stripped Oil Pan n517rv 3rd gen T4Rs 7 08-30-2020 02:46 PM
timing belt change - help needed dthlo 3rd gen T4Rs 5 03-10-2013 12:46 PM
Engine change advice needed HELP! 1oldyota 3rd gen T4Rs 2 11-13-2012 10:39 PM
A little fluid change advice needed. Blanco 3rd gen T4Rs 10 12-25-2011 10:53 AM
