Old 06-14-2020, 12:08 AM #1
jaxX- jaxX- is offline
Real Name: Matt
jaxX- is on a distinguished road
Real Name: Matt
A/C Evaporator Core Replacement
Sup guys, I'm thinking about trying to replace my evaporator core myself. There's not much online about the details, but I'm going to see how far I can get and try to document as much as I can. I'm going to start tomorrow hopefully and at least get the dash out. I've just recently graduated college and have more than enough time on my hands, so I'm fine with it taking multiple days to complete.
Hopefully I can get it done within a week.
jaxX- is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 09:07 AM #2
Real Name: Skip
Real Name: Skip
Be sure to label everything you take apart and photos as well so you don't have too much trouble reassembling it all!
2004 Limited V8
Old 06-14-2020, 07:04 PM #3
Real Name: Matt
Real Name: Matt
Hey guys, day one on the evaporator core replacement is coming to a close. I'm waiting to pick up the new core tomorrow. I'll post some pics of what I had to do and show where I'm at now. I have pretty much every bolt/screw in a labeled bag.
Removed lower cover under steering wheel
Imgur: The magic of the Internet
Removed metal piece under that
Popped off center console bezels (Ignore extra wires)
Removed rest of center console
Removed Center dash cubby and hvac controls
Removed Center dash bezel
https://imgur.com/wiiiLHv
Removed Radio
https://imgur.com/gEBmMcP
Removed trim around gauges (no bolts)
https://imgur.com/Sp9FTnR
Removed trim piece under glove box, glove box and cubby above glove box (was intimidated by gauges at first)
https://imgur.com/3WQr16j
Finally removed gauges (two bolts at top release wire harness)
https://imgur.com/htARDkN
https://imgur.com/7hetsZY
Next, removed passenger side air vent and took out all bolts holding the actual dash in place so as to get it fully removed
https://imgur.com/Yqu5aAy
Had to get some deep well sockets to release steering column so I could get the dash brace to move.
https://imgur.com/EYFpkQJ
At this point, I was a little frustrated and the pictures are less frequent. I disconnected the fuse box, ecm, and anything else that the large brace was connected to. There are a few bolts on either side that are accessible from the door jam that I removed and/or loosened to help free the brace. There are also brackets going to either side of the trans tunnel that needed to be removed.
After I had some play in the brace, I went around the heater box and evaporator and unbolted anything that was holding them in. I managed to get each of them out finally.
https://imgur.com/EfyyBI7
https://imgur.com/oA9SvLK
https://imgur.com/FGnooHK
https://imgur.com/1RguBgH
The evaporator has screws running down the middle that need to be removed in order to get inside to the core. I had to remove a servo in order to rotate a fin to pull it apart.
https://imgur.com/BNz7xzl
Here is the busted core, which i will be replacing and reassembling tomorrow.
https://imgur.com/cwMUG6y
If there is anything that is unclear or any questions, just let me know. I know that I didn't do the best job documenting the process, but I figured it's a lot better than anything I've been able to find. I'm flying mostly blind on this but it's coming along alright.
Old 06-14-2020, 10:07 PM #4
dsanford dsanford is offline
dsanford will become famous soon enough
I’m doing this exact same repair very soon. Thanks for the tread. I looked through the factory service manual and I’m not looking forward to doing this but I also didn’t want to part with $1000 to have a repair shop do it. Looking forward to seeing your progress.
2006 GGM Sport 4WD / Lots of maintenance from neglect (from previous owner) / Interior & Exterior LED swap / Sony XAV-AX1000, Kicker front door speakers, Kenwood tweeter replacement / Diode Dynamics SS3 Fogs
dsanford is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 03:01 AM #5
Real Name: Matt
Real Name: Matt
It definitely can look and feel intimidating at times. I don't have any special tools and I have rarely looked to the FSM for guidance honestly. Just make sure you have some deep well sockets as there's plenty of nuts where you'll need them. I worked in a mechanic shop last summer and winter break during school so I felt pretty confident going in, but just make sure to take your time and keep everything organized. I managed to get the evaporator out completely in about 3 1/2 hours. I figure I can get everything re-assembled in 4-5 hours hopefully
Old 06-15-2020, 04:23 PM #6
Real Name: Matt
Real Name: Matt
Just finished getting everything put back together and A/C charged up. Blowing cold and will update in a day or two to report if it's staying cold. If anybody wants I can post the few pictures that I have but it was basically going in the reverse order of taking it apart. I kinda got carried away and didn't take too many pictures along the way of reassembly, so I apologize for that.
Only big hiccup was getting the main brace that goes across the entire width of the car back in place but it wasn't anything major. Overall took me probably 5 hours to completely reassemble and have it parked back in the driveway, totaling about 8 1/2 hours of work in all.
Old 06-16-2020, 06:08 AM #7
Real Name: Skip
Real Name: Skip
I haven't read your process in it's entirety but I will when I have more time, but did you also replace the heater core while you had it apart?
2004 Limited V8
Old 06-16-2020, 07:14 PM #8
Real Name: Matt
Real Name: Matt
Nope, my mechanic told me he heard what sounded like knocking when I left it or him to diagnose a/c problem. I was going to have another shop do the work and fork over $1000+ but I decided if it was gonna kick the bucket sooner before later then I would try to do it myself. I really want to spend as little as I can on it for the time being just so I don’t end up dumping a bunch of money into it the. The motor blowing
Old 06-17-2020, 10:46 PM #9
8 1/2 hours total, that’s pretty good. I’ve set aside a whole weekend to do this job haha. I like to consider myself mechanically inclined but with something that deep in the bowels of the dash I want to really take my time. Looking forward to the update to see if it’s still working well for you.
Old 06-17-2020, 11:14 PM #10
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I really appreciate you taking the time to grab pics for this, thats awesome! A tip is that you can embed the images from imgur into your post using the html link in imgur and pasting it into the forum. It will look like this when you paste the text into the edit window:
HTML Code:
<a href="https://imgur.com/8NeEFMO"><img src="https://i.imgur.com/8NeEFMOl.jpg" title="source: imgur.com" /></a>
You can change the size at the bottom of the imgur window, I like medium and large thumbnails. If you want to change size on the fly, change the letter at the end of the src section to t=small, m=med, L=large, h=huge. Hopefully the asterisk is lined up correctly over the letter I'm referencing, I think it should be monospaced text.
HTML Code:
Small Pic Example:  <a href="https://imgur.com/8NeEFMO"><img src="https://i.imgur.com/8NeEFMOt.jpg" title="source: imgur.com" /></a>
Medium Pic Example: <a href="https://imgur.com/8NeEFMO"><img src="https://i.imgur.com/8NeEFMOm.jpg" title="source: imgur.com" /></a>
And then when you preview or submit, it will look like this:
y=mx+b is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 11:45 AM #11
71-Cruiser's Avatar
71-Cruiser 71-Cruiser is offline
71-Cruiser is on a distinguished road
71-Cruiser's Avatar
Everything has to come apart
71-Cruiser is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 12:37 PM #12
Captsolo Captsolo is offline
Captsolo will become famous soon enough
I replaced the AC compressor on my 2005 4runner, and it's been holding the "cool" for two years. The new compressor at Amazon was $200.
Compressors have a hundred rubber seals in them, that is why when they fail and leak the refrigerant you buy only new replacement compressor.
Captsolo is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 08:31 PM #13
DreamRun08's Avatar
DreamRun08 DreamRun08 is offline
Real Name: Kapila
DreamRun08 is on a distinguished road
DreamRun08's Avatar
Real Name: Kapila
puttin my truck back together after installing new evaporator. there is a wiring connector on passnger A pillar that i can't find the other side for. anyone know what it is for?
2008 Sport 4WD
BFG Rugged Terrain 265/70/17R, FN Wheels f(x) pro, BORA .75" wheel spacers, Daystar 2.5/1.5 spacer lift, Xenon Depot 5000k Xtreme HID kit, K&N air filter.
DreamRun08 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 05:35 PM #14
This guy does a 2006 4runner evaporator replacement in 15 minutes in this youtube.
I have a 2005 4runner an mine needs a new Denso evaporator - $101 at Amazon
youtube 2005 4runner evaporator AC - Bing video
Old 09-25-2020, 12:26 AM #15
DreamRun08's Avatar
Real Name: Kapila
DreamRun08's Avatar
Real Name: Kapila
well i found what i was looking for and i got it all back together, but for some reason the truck doesn't start. Im almost 100% sure i got all the electrical connectors back together.i'm about to freak. the truck will turn over but just won't start. anyone have a clue what it could be?
2008 Sport 4WD
college , core , evaporator , graduated , recently
2011 bad AC evaporator core? mag4x4 5th gen T4Rs 12 11-24-2023 07:20 PM
4th Gen Evaporator Core Replacement TungstenSquash 4th Gen T4Rs 13 10-04-2020 01:24 PM
AC Evaporator Core Replacement - non OEM parts? danthemanx07 4th Gen T4Rs 0 07-11-2018 12:30 PM
Evaporator core, doing it myself IOPturbo 4th Gen T4Rs 2 04-16-2014 02:43 PM
Evaporator Core Replacement tuteng 4th Gen T4Rs 0 07-15-2012 04:59 PM
