Old 05-03-2021, 01:43 PM #1
JBend JBend is offline
JBend will become famous soon enough
Transmission slip
Just passed 178k and the other day pulling onto the highway it slipped fairly bad going from first to second. Didn't happen the rest of the day, today it slipped a little from 2nd to third and downshifted a little rough from 4th to 3rd. No documentation that the trans fluid was ever changed or flushed and am scared to touch it due to that and high mileage. Any help?
JBend is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 02:40 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I'd do a drain and refill, drive it for a day or so, do another drain and refill and then do at least one more. Then do another in 15K miles and stay on a schedule of 30k miles. I'd use the appropriate fluid from Toyota or use Valvoline Maxlife, which many on this forum use.
Old 05-03-2021, 02:41 PM #3
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
I got 155,000 on my 2005 and tranny never slipped. Dealer did a 6-quart D/F and changed the filter at 105,000 miles.
I'd try a 6-quart D/F before I order a remanufactured one or took it into a top transmission repair shop.
Scotty Kilmer recommended a bottle of tranny stop slips in one of his videos.
Are you towing?
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 03:15 PM #4
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
506,000 miles on my A750F transmission. Did a fluid swap last year around 490,000 mi and it has very mild wear. Still kicking.
If you tow or get the fluid hot then changing out at the correct interval is required. There is a chart somewhere showing how long the fluid can last at different temperatures.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 03:28 PM #5
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Id be more concerned the fluid is low, causing the slip vs the tranny failing. The cooler lines beneath the radiator rust thru and you may have a leak in the circuit.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 04:56 PM #6
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Originally Posted by JBend View Post
...am scared to touch it due to that and high mileage. Any help?
Check the fluid level, or have a reputable shop do it if you're scared to touch it.
If it's low, top it off with specified fluid (you didn't state your model year) and check for leaks. Especially the front cooler pipes that run under the radiator as DrCoffee said.
If the fluid level is right, I'd either exchange the fluid or have a reputable shop do it. No power flush, just a fluid exchange. Did mine at 164K miles on factory fluid and it's still running right at 251K miles. And yes I'll be exchanging fluid again soon.
waypoint is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 06:33 PM #7
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
On the driver's side of the transmission, just under the area of the gas pedal, you'll see a white electrical connector. Check that for corrosion and spray it with a little something called De-Oxit.
A few years ago I had an issue with corrosion on that plug and it caused me some harsh shifting.
Montego Murph is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 07:08 PM #8
This is very interesting...last week I took it to a local Toyota dealer just to have an inspection done...they said I had a radiator leak but levels were fine...I'll have to see if there's a wet spot where I park and check those lines....hmmmmmmm
Old 05-03-2021, 07:56 PM #9
Drcoffee's Avatar
Drcoffee's Avatar
If you remove the front skid plate, you will have full access to the lines. Check the radiator too. Any sign of pink crusty stuff replace the radiator. They are cheap. $90-$100.
Old 05-03-2021, 08:02 PM #10
Syr4RinNC's Avatar
Syr4RinNC's Avatar
When my 03 transmission went it was the temperature cooler and it got way too hot and fried. If you have an obdii scanner I’d hook it up and see what you’re running at highway speed.
But overall I’d try to tread lightly until you get a handle on it
Old 05-03-2021, 08:06 PM #11
I ordered one already just for precautionary reasons buuuuutttt went with a CSF high performance and all new hoses and clamps. For future plans...to support other, things....
Old 05-04-2021, 08:56 AM #12
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
Not to complicate things as there is enough work already, but while your in there your inches away from the water pump, thermostat and at least the idler pulley's.
Don't forget also, one of the idlers is reverse threaded, I believe the tensioner.
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
day , documentation , fluid , slipped , trans
Transmission slip...solenoid? "JV" Classic T4Rs 7 12-31-2018 04:46 PM
HELP!!! Transmission Slip montijo505 4th Gen T4Rs 15 03-05-2017 08:23 PM
Transmission Slip? Tleahcim 4th Gen T4Rs 5 03-04-2014 08:40 PM
Transmission slip (95) DoctorJest Classic T4Rs 6 12-18-2010 05:43 PM
Transmission Slip/Miss coreyapotter Problems & Warranty Issues 2 11-27-2007 09:23 AM
