05-04-2021, 08:10 PM
#16
Originally Posted by Monty87ls
Your comment didn't pop uo until after I posted my last one, Do you know which ones they were? they have 2 different grade apparently one lower one higher. The higher having a 10 year warranty but now that I've added them to the cart the shipping has gone up and price due to all of them coming from different warehouses. Guess ill do a bit of thinking on it and see what I wanna do.
At this point I'm sure whatever I choose will last me as long as I need it to.
Rockauto website can be weird. I have had the same issue with shipping from diff locations. I close it down and come back later to check the shopping cart and suddenly they all ship from the same warehouse.
Im beginning to wonder if RA is being deceptive.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
05-04-2021, 09:49 PM
#17
Interesting I may give that a try.
05-08-2021, 12:01 PM
#18
Toyota OEM are new calipers
I put 2010-2014 calipers on my 04 v8 sport for less than $320 shipped. Look around, some dealers go almost 35% off list online. Remans are good for 20-30k, new oem usually get 60-80k at least. For me the extra $$ was well worth it. Running remans in the rear for close to 25k, will most likely go new there when they fail. If part number is only 10 digits, it's new. If it's 12 and ends in 84, it's a reman.
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
Reason: explanation
05-08-2021, 01:05 PM
#19
Real Name: Jeremy
Real Name: Jeremy
All (aftermarket) reman are sub-par
I agree with most of this concept too. Plenty of online (Toyota) dealers will sell at far more discounted rate than my local dealer.
The aftermarket (new and rebuilt) use an oem casting to start and use whatever cheap guts they can source. They customize the exterior for their brand and fluctuate the price accordingly.
I bought a pair (oem) from a salvage yard online and the Toyota caliper rebuild kit from a dealer. The kit comes with the caliper boots (2 types), piston seals, bore seals and grease. It also comes with the little boots for the bolts. DOES NOT INCLUDE PISTONS
Oem pads. Came with the pins and clips and the spreaders.
YouTube is your friend for the process. 45 min sans paint.
Rebuild kit, Brake clean, wire wheel, pic tool, scotchbrite cloth, tap for the bleeders and new bleeders.
$150 done
My best advise for this approach is to pay close attention to two elements.
1. OEM casting. If this is overlooked then you may as well have just bought used remans.
2. The pistons. NO RUST. They should be corrosion free. There will be some brake dust residue but it should wipe off easily.
Reason: Fat thumbs and bad eyes
05-08-2021, 02:14 PM
#20
Real Name: Skip
Real Name: Skip
$150 done
The $150 cost you posted, is that for 2 or 4 calipers, and does that include the new OEM pads?
2004 Limited V8
05-08-2021, 02:43 PM
#21
Real Name: Jeremy
Real Name: Jeremy
I should have been more clear. Hope this helps.
$150 for the front calipers. Oem Toyota
$30 for the rebuild kit. Oem Toyota .
$50 pads. Oem Toyota
$8 for the bleeders
No cores necessary. This allowed me to do all of the work first and minimal downtime for the rig.
05-08-2021, 04:01 PM
#22
Real Name: Ed
Real Name: Ed
I bought brand-new aftermarket calipers several years ago from Advance Auto, they're definitely non-OEM castings. Raybestos now sells new castings (no cores needed), they're probably from the same overseas manufacturer.
05-09-2021, 08:13 AM
#23
I went with the (new) Raybestos Element 3 coated calipers after years of dealing with the crappy remans, couldn't be happier.
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
05-09-2021, 09:40 PM
#24
If I may ask how long have you had them? Miles?. At this point Im just trying to get good brakes and want them to last until I can rebuild my damn life and move back up to something a bit more fitting to my family. I did a lot of work the I got it and this summer shes gonna need some more love and If I can manage Ill strip the plastic flares off and repaint them just to freshen it up again.
05-10-2021, 07:21 AM
#25
Just replaced the calipers, rotors and pads this weekend after my passenger side one stuck on me on Friday. Got them from Advanced with the warranty since it seems to be a common occurrence on these things.
05-10-2021, 12:18 PM
#26
Pulled the trigger today. Went with the new Raybestos element3 calipers. Read lots of reviews of them seem to be all positive, the price was around what I would pay after cores and all that and saves me having to send them back.
Says limited iifetime so guess we shall see how that goes. Paid $726 and some change after a coupon and shipping.
Also ordered a full 6 piece stainless steel brake hose set cause why not.
05-28-2021, 06:16 AM
#27
Banned
Real Name: Tommy Bahamas
Banned
05-28-2021, 09:00 AM
#28
Correction the Nugeon brand has limited lifetime. Never heard of them before I don't think.
Nugeon are fine I had them on me E36 BMW...
Cardone kinda sucks. I use Cardone remans (not just brakes... PS pumps, racks etc) all the time for work, but only when I have to. A fair amount are defective out of the box. I just put one of their new PS pumps on my 4runner when I did the Head Gasket job and it is fine for now... But I always wince when I use Cardone. YMMV
2004 Sport 4.0
05-28-2021, 09:02 AM
#29
Originally Posted by FordF150
More crap advice from someone who has proven they don't know what they are talking about (see "Captsolo" banned, this is the same guy)
Do calipers when necessary IE sticking pistons, pistons that retract hard when doing the brake job, or when mileage becomes a concern.
2004 Sport 4.0
05-28-2021, 09:34 AM
#30
If you wince when you use Cardone, Dorman must be good for full cardiac arrest. I refuse to use their junk.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
