Old 06-12-2021, 09:36 AM #1
robdog09 robdog09 is offline
robdog09 is on a distinguished road
Funny Battery Issues
Ive replaced the battery in my 2006 SR5 three times since 2015, at approximately 24 months of life each. Typically the starting begins to slow, maybe for a month or so, then it will eventually die. I was always able to get a few extra weeks by jumping it and getting it on the highway, but it always resulted in a battery swap. It just became the norm.
This past wk, something new happened. On Thursday, the battery light came on, and then when driving home from work on Friday, I barely made it home. The radio turned off while driving, AC flickered on/off, dash lights came on, etc. I was able to make it, but when I finally turned the car off, it had no juice to start again and was completely dead.
Obvious attention goes to the alternator, but I figure I wouldn't have survived this long if the alternator was the problem. Do alternator's have a slow death (i.e. 5-6 years) like this?
Anyone ever have an issue with a short draining the battery? Other culprits to look at that would be of interest?
One item worth mentioning is that I just completed an 850 mile drive ATL=>DFW in the car, straight through. That is the longest Ive ever driven it bofore. Not sure if that matters.
robdog09 is offline   Reply With QuoteReply With Quote
Old 06-12-2021, 01:17 PM #2
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Battery
Let me start by saying that most of my batteries I have owned in all of my vehicles lasted an average of at least 5-6 years I even had a few that lasted 9 years not just once but twice. All my vehicles are Toyota and had good luck with Toyota batteries the last 15 years. I would suggest try it and see what happens check your charging system and also current draw check the battery cables for corrosion and poor contact, if you have aftermarket alternator go back to OEM or get a Denso unit. Post up what you find.
vipergrhd is offline   Reply With QuoteReply With Quote
Old 06-12-2021, 01:18 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
I agree with your thoughts. I’d evaluate the alternator, Eval for a parasitic draw or short. I think it’s also worth mentioning the Panasonic oem battery is a solid 10 year battery. The aftermarket ones just don’t last very long
Old 06-13-2021, 07:47 AM #4
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
In my life alternators usually went bad quickly/instantly, however I did have a GMC truck that had an alternator go to 11.8 volts and was hard starting. I would do both alternator and battery and watch out driving on low voltage and jumping a lot, electronics do not like it, just my 2 cents.
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 04:16 PM #5
I tried jumping and charging the battery to no avail. Ended up getting a new battery, and obviously the car cranked up.
The guy at advanced auto said that when the car is running, the charge from the cars system should be reading north of 13.9 volts -- thats what the alternator puts out. If its somewhere in the 12 range -- implying the alternator is not contributing anything to the circuitry -- that would imply an alternator issue.
Is that true? My batt read at 12.37 while running.
Old 07-20-2021, 06:31 PM #6
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
He's right. It should read at least 13.4ish to 13.9. 12.37 means its not getting a charge. Most likely your alternator.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 09:11 AM #7
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
I have seen performance on alternators degrade over time associated with bad diodes. Check for AC voltage if you can - a good quality meter like a Fluke is required.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
battery , car , driving , home , slow
Any issues disconnecting the battery? kaitlyn2004 5th gen T4Rs 16 09-26-2020 10:08 PM
Battery issues (I think?) Apemeister 4th Gen T4Rs 1 09-10-2014 09:47 PM
Battery/Alternator issues gtarbmx 4th Gen T4Rs 14 10-14-2013 12:00 PM
Funny License Plates + Funny Car Memes trev0006 Off Topic 0 09-02-2013 02:32 PM
Couple battery issues maybe? T?@\7 4th Gen T4Rs 9 01-18-2008 04:31 PM
