Old 05-08-2021, 07:43 PM #1
joshik joshik is offline
joshik will become famous soon enough
Are my 6112s leaking?
Noticed that my 4r feels different lately both on and off road over small-mwd bumps and rocks.
It seems to drift when hitting bumps at a decent speed... Kinda scarry feeling. I don't ever recall it doing that before.
Looked at the coil overs real quick and they look dirty of course but it almost looks like a film of oil... Not sure if it's from previous cv axle leaks but that was a long time ago and I don't remember it getting all over the coils/strut.
What ya think? Imma get under the 4r and inspect more closely later tonight.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 11:25 AM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Spray the front suspension down with a degreaser and hose to clean them up some so you can get a better visual. Otherwise, the driver side shock looks fine, passenger side looks a little suspect but hard to tell from the pics to be sure.
Drift like you describe could be caused by a couple things. Alignment being off is one and the rear panhard being at an angle from the lift.
I'd have the alignment checked and then you can also check front shocks by pushing down on each corner of the hood to try and compress the suspension a little and see if one side bounces more than the other. Or have someone drive next to you and watch the wheels to see if one seems to be bouncing while you drive. If so, then that shock is probably bad.
Don't limit your troubleshooting to the front tho. The rear can also cause your issue.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 08:05 PM #3
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I'd add to xtremewlr's notes that just one shock leaking could cause some weird behaviour. Both fronts or both rears aren't likely to fail together... one can pop a leak across a seal and no long give good ride control; and provide erratic handling.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
axle , bumps , film , oil , previous
6112s with heavy springs RDOOGZ89 4th Gen T4Rs 2 04-16-2019 08:59 PM
HELP!! 6112s from 2014 on 2006??? mnemonic 4th Gen T4Rs 2 01-02-2019 12:30 PM
Front struts (6112s) are leaking, recommendations please Mo's TE 5th gen T4Rs 16 10-17-2018 05:15 AM
Will OME 885s fit over Bilstein 6112s 07V8 4th Gen T4Rs 6 02-22-2017 01:04 PM
Bilstein 6112s for $576 joshik 4th Gen T4Rs 2 04-12-2016 03:10 PM
