Old 05-12-2021, 11:53 AM #16
Originally Posted by sundance21 View Post
Lubeguard is a friction modifier. Slipping is often associated with binding parts that restrict flow. Lubeguard will definitely help if this is the case. Cheap and can't hurt.
yes its cheap & wont hurt, just saying its not really designed for slipping & doesnt say anything about using it for that issue. slipping transmissions are usually more related to worn out clutches.
Old 05-12-2021, 10:17 PM #17
sundance21 sundance21 is offline
sundance21 is on a distinguished road
Again, you show how little you know about transmissions. Slipping from clutches usually involve multiple gears. Fixing a bad clutch requires tear down. It may very well be an issue in the valve body that can be fixed without a tear down.
sundance21 is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 09:32 AM #18
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
I would drop the pan and clean the magnets good. That should give you an idea of how bad things are. Can throw in a new strainer as I believe they are fairly cheap. Likely a thorough cleaning with some fresh fluid should be all you need to keep her going..
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 11:54 AM #19
what? again?? well if you seriously think adding a bottle of lubegard will fix a slipping transmission or that it has to be multiple gears for worn clutches, then i clearly know more than you.
& why do slipping clutches usually involve multiple gears? clutches can go bad in just one or 2 or all gears. i have had transmissions that slipped only on 1-2 shifts, or 3-4 shifts or only going into OD & even only in reverse, its not always multiple gears & is very common to only be 1 or 2. & yes its obvious fixing worn clutches requires tear down, thanks for enlightening us all on that...
so, if its an "issue in the valve body" youre actually suggesting lube guard will fix that? highly doubt that one. or that removing a trans cooler (which he stated he didnt touch & V6's dont have aux trans coolers) will get dirt & "trash" in the valve body & cause slipping? you are aware theres a filter before fluid goes to the valve body right?? & if by some miracle this "trash" gets to the valve body, how will lube guard remove that piece of stuck debris?? i was just stating a fact lubegard is designed for fixing shudder, if it was for slipping it would be advertised that way too.
i wasnt trying to argue with you, but your ASSumption i dont know about transmissions are rather comical. but thats ok, i just remembered you are the guy that thinks maxlife destroys transmissions... yet the link you posted that you found searching google was just some guy that thinks his old already worn trans was damaged from using it with zero proof or logic it was the fluid that caused his issue & 9 out of 10 people in that link laughed at the guy & proved him wrong!
think what you want, but the statements & "advice" you provided in this thread & the maxlife nonsense are flat out wrong. have a nice day.
Old 05-13-2021, 12:38 PM #20
Yeah. You don't like me. I stand by what I wrote. Bash away...
Old 05-13-2021, 04:56 PM #21
also an assumption... i dont know you so dont have any personal feelings towards you. i simply mentioned lubegard is designed more for shudder & probably wont do anything for the OP's stated symptoms of slipping & that he explained he didnt touch anything in his original post. for some reason you felt the need to post a condescending remark assuming i dont know anything about transmissions even though what i posted is true... such a friendly comment.
i stand by what i wrote as well. nothing personal & no bashing, just facts.
Old 05-13-2021, 08:16 PM #22
JBend JBend is offline
JBend will become famous soon enough
Yupp. A 5qt flush and she's doing fine. I've got abottle of fluid they gave me but haven't checked it yet.
Thanks to everyone for the tips and advice.
JBend is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 09:17 AM #23
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
Amazing how new fluid D/F can solve a shifting problem. 4runners hold 12 quarts of tranny fluid.
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 11:11 AM #24
it was 2 qts low on fluid that caused the problem... amazing how having the right level can solve a shifting problem.
car , check , dealership , flush , transmission
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Transmission Skid plates increase transmission temperature? randy88fj62 4th Gen T4Rs 10 05-11-2021 06:43 PM
P0705 Code - Transmission hard shift into gear after stop, transmission slipping kirkharrald 5th gen T4Rs 2 11-20-2020 08:26 PM
Transmission Fluid - bg transmission service Yuri 4th Gen T4Rs 2 02-09-2018 02:01 AM
