01-05-2014, 03:17 PM
need gas tank skid removal help
im looking all over the forum and can not find out how to take off the gas tank skid plate. i have the thing up on ramps but can not get to the bolt that is right above the axle. anyone have ideas on how to remove the skid. might try a jack after lunch but as of now i can not get a socket on the bolt
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
01-05-2014, 06:13 PM
12mm swivel socket helps or at least a swivel/u joint adapter up in there. Long extensions too maybe? You will get it. It's just tougher on your back in the driveway.
Lemme know if there is anything more specific that you are having troubles with. I might have done a few of these over the years...
Bud
BudBuilt Tough Off-Road and Overland Armor
Bud Rosenberger
Rob Daugherty
http://www.budbuilt.com
828-572-1202
01-05-2014, 08:17 PM
Bud
Well I did not end up removing the skid. It is making contact with the gas tank but was not rubbing. I put a piece of rubber inner tube from a bike where the dent is in the skid for now and might pull it down but for now it seems safe
01-05-2014, 11:45 PM
I used a combination of long extensions and the swivel u joints. PITA and it took a half hour for the one bolt as the drive shaft really gets in the way, but it comes off eventually.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
01-05-2014, 11:56 PM
i even tried jacking from the rear hitch and putting on stands but i didnt have room then. also didnt have the tools needed on hand and was starting to rain so its together and safe for now. still need to hit the dent out of it at some point
01-05-2014, 11:58 PM
I forgot you weren't lifted! Yeah that would make it much harder.
01-06-2014, 12:49 AM
What made it easy for me (other than being on a 4 post lift, in a heated garage) was some spline drive socket from Lowes. Each socket has a built in U joint. I have never used them for anything else, ever, but they made removing and re-installing that bolt effortless.
11-01-2019, 10:10 AM
Reviving thread. Gotta say that bolt by the driveshaft up front was a beotch. I spent over an hour on it. Heavily rusted. Cant use a socket as its too close to the drive shaft. I was able to get it 3/4 of the way of with a ratcheting wrench but then it got rounded off. Finally said **** it and just dropped the skid with it on.
I was able to do the fuel tank belt with it on, but it was tight and awkward. If it ever really has to come off, its going to be a Dremel. A small worn disc will do the trick because a new one is too big. Its easy to access the back of the mount and I would drill out and put a new bolt and nut up there.
Sheesh terrible location for this bolt.
11-01-2019, 05:01 PM
When the shop dropped my tank, they didn't mention any difficulty getting to any bolts.
They had the tank dropped before I could stop by to help out.
Though maybe up on a lift with the axles fully drooped, gave them better access to that pesky bolt {just a wild guess}.
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
11-01-2019, 05:55 PM
I actually snapped the head off that bolt a couple of weeks back when I had to replace a broken fuel tank strap. I actually broke another on the frame side as well. I had the skid sandblasted and powder coated, so it’s all ready to go back on, but now I need to remove the driveshaft to be able to drill that bolt out and retap the hole. What a crappy design! EVERY bolt was completely rusted into the frame, so I guess I’m lucky only 2 broke. I chased all the holes with a tap, and used new bolts, with anti-seize this time, so hopefully if it ever needs to come down again, it will be easier next time!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
11-01-2019, 07:18 PM
My bolt was at a 45 angle and it was just terrible. Impossible to get a socket on behind the driveshaft. I honestly think that some of the 4Runners have a slightly different angle on that bolt. I ended up grinding the **** out of that thing with a Dremel. I then drilled a hole straight up and down and tapped it to 8 mm by 1.25. Easily threaded a bolt and no longer a problem to access.
I also replaced all the other rusted bolts as well, so six new bolts. It 'll be super easy to change out a fuel pump next time I need to bring it down, if needed. I also sanded the whole thing down remove rust and repainted it.
I got to use a lot of my tools though. Future readers, if you're even thinking about bringing down your fuel tank skid plate buy a Dremel, Milwaukee M12 right angle drill, and a set of left-handed drill bits. You'll need them. Drill has saved me on many occasions in tight spaces.
Oh, and f road salt.
11-01-2019, 07:50 PM
May have to do this in the near future, wouldn't disconnecting the driveshaft and moving it off to the side make the job much easier?
11-02-2019, 08:23 AM
I’ll have to look at maybe redrilling in a different spot as you did, because mine was also on an angle. It’s a crappy location no matter what though.
11-02-2019, 08:27 AM
Probably. That is/was my plan since there is no way I can get to it to redrill and tap it. I am considering doing what that other guy did though and maybe drill in a different spot since it may be easier to do that, than to try to drill out the exact center of the broken bolt.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
