Old 05-13-2021, 05:18 PM #1
vicho09 vicho09 is offline
vicho09 is on a distinguished road
Exclamation I think my 1GR is leaking oil.
Hello, first of all I want to tell you guys thanks for accepting me here because im new, and also i am very uneducated in the mechanics of a car, i only know the basics, so i hope i can be educated.
This is a 2006 v6 4runner with 4WD. I inherited from my mother who changed her car. I've used it for a couple of months and now looking in the engine bay i found a lot of oil in the left bank of cylinders (looking from the front). I started to follow but i cant realize where it is from, i dont have the knowledge. Then i crawled under the truck and saw even more. Everywhere where i found oil is in the pictures. I found it weird that in the right bank there was no leaks. Also, the idle is perfect, always in 500rpm and solid, it doesnt move.
On another note i also found something formed up, which could also be a leak. I think is in relation to the fuel lines/pump. Its also in the pictures.
I would like to know what are your opinions on this, what do you think could've caused this? Should i do something? should i take it to a workshop? Should i keep driving it normally?
** The truck has 100,000 miles**
Thank you very much before hand.
I think my 1GR is leaking oil.-whatsapp-image-2021-05-13-17-02-15-1-jpeg  I think my 1GR is leaking oil.-whatsapp-image-2021-05-13-17-02-16-1-jpeg  I think my 1GR is leaking oil.-whatsapp-image-2021-05-13-17-02-17-jpeg  I think my 1GR is leaking oil.-whatsapp-image-2021-05-13-17-02-18-1-jpeg  I think my 1GR is leaking oil.-whatsapp-image-2021-05-13-17-02-22-jpeg  I think my 1GR is leaking oil.-whatsapp-image-2021-05-13-17-02-20-jpeg  I think my 1GR is leaking oil.-whatsapp-image-2021-05-13-17-02-15-jpeg  I think my 1GR is leaking oil.-whatsapp-image-2021-05-13-17-02-16-jpeg
vicho09 is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 05:59 PM #2
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
The last picture looks like grease has been slung off the driveshaft.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 06:48 PM #3
jonothehut jonothehut is offline
jonothehut is on a distinguished road
How often do you have to refill/add oil?
jonothehut is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 07:24 PM #4
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is a jewel in the rough Drcoffee is a jewel in the rough Drcoffee is a jewel in the rough
Drcoffee's Avatar
Probably just the valve covers are leaking. Passenger side is a piece of cake. Just get a 10mm socket wrench, FIPG and go at it.
1999 4Runner SR5 4WD 3.4L AT 232,000 miles
2007 4Runner Sport 4WD 4.0L 222,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP
Drcoffee is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 10:22 PM #5
RTRSPRFTR RTRSPRFTR is offline
RTRSPRFTR is on a distinguished road
Cool
timing cover leak in the 5th picture where there's one point the fipg eventually degrades. quite common on early 1gr's. there was a tsb for it. it's not hard to fix yourself but time intensive so costly paying a shop to do it. most just let it be if don't have to refill often.
edit: adding pic showing where leak often comes from.
I think my 1GR is leaking oil.-a5a0d5c7-55d0-4b7b-a20f-b90d99610275-jpg
RTRSPRFTR is offline   Reply With QuoteReply With Quote
Old 05-17-2021, 11:05 AM #6
that last pic of the dipstick looks to be severely overfilled, very different from the 1st pic of the dipstick... but they can read wrong if checked right after the engine is shut off. make sure to check the fill level again to verify its not overfilled. pull the dipstick out a few times & wipe it off each time, be sure the engine is off for awhile to ensure no oil is climbing up the dipstick tube.
as others mentioned it could be a valve cover gasket if its coming only from one side & running down to the bottom of the engine. you can try & wipe everything clean from top to bottom with a couple towels & some paint thinner or brake cleaner etc, then go for a drive & check if you can see where the leak is coming from. that is the proper way to verify a leaks location... dont do what one guy on here does & just blame the oil for the leaks & continue to drive it, leaks happen for a reason like failed gaskets, loose nuts/bolts holding items like valve covers & oil pans or bad rear main seals etc.
if you dont feel comfortable cleaning & checking for leaks or replacing the part causing the leak, take it to a reputable local mechanic to find/fix the leak. not the dealership who will charge more than any other shop.
best of luck!
Old 05-21-2021, 07:38 AM #7
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
What type of oil are you using? synthetic or conventional.
True story: I switched to synthetic after 11 years of conventional in my 2005 V6 4runner with 160,000 miles. This was a "try-out"! Immediately I got oil drips on the garage floor, so I drained it and put NAPA conventional 5W 30 back in.
Immediately the oil drips slowed down. After 6 months they were down to three drips a month. Now, I'm down to one drip a month.
Synthetic is overrated IMO. In my car where I change the oil every 5000 miles conventional is better.
Kilmer on older cars using synthetic.
scott kilmer on synthetic oil - Bing video
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 12:40 PM #8
leonp24 leonp24 is offline
leonp24 is on a distinguished road
Captsolo-fordf150 - this must be a lie. Haven't you said that synthetic is to slippery to do any good in your engine? Stupid is as stupid says.
leonp24 is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 11:09 AM #9
just to be clear here, captnsolo/F150 stated on here numerous times he uses 10/40 oil now because the bahamas doesnt sell 5/30 because its too hot there. & that synthetic oil causes head gasket issues...
if an engine leaks on thick conventional oil, there is a gasket, rear main seal or other problem causing the leak, its not synthetic oils fault.
& scotty uses STP FULL SYNTHETC oil on that video in the high mile toyota...
bank , car , found , oil , pictures
Can anyone tell me what is leaking from this? mig0s 3rd gen T4Rs 2 07-30-2019 09:58 AM
Leaking oil? Sup41 3rd gen T4Rs 6 08-18-2017 05:07 PM
Leaking Oil? rkjohns1 3rd gen T4Rs 9 10-15-2015 08:27 PM
Rear differential leaking housing leaking? Schwooby Classic T4Rs 5 07-01-2014 06:43 PM
leaking oil please help. Donovansolis 3rd gen T4Rs 11 09-12-2010 05:15 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
