What springs are you running? (Winch and Bumper)
Looking to see what everyone is running for springs and/or suspension up front. I currently have 5100s all around with the fronts set on the top perch (2.5") using OEM coils and Toytec superflex springs (2") in the rear. I currently have a low profile steel bumper in the rear and plan to weld on a swingout and add a drawer system later. I'll probably end up going with the Superflex HD coils at some point for the rear. My question is, what are people running in the front for coils with their 5100s? I have a Coastal Offroad front bumper and am going to add a 10k Warn winch. I'm thinking the OME 885 or 886 coils to support the extra weight and keep my 4runner level. Toytec also makes a 620lb coil that could work. I also need the lift to keep clearing 33s.
Essentially, what spring would you recommend or have good/bad experience with for the front if I have 5100s, a bumper, and a winch? Looking for 2.5"-3" of total lift. Thanks!
06 Galactic Limited on 33's, Rear locker, Bilstein 5100s, Toytec 2" Superflex Springs, Whitson Metalworks Rack, Squadron Sport Ditch Lights, Dual Viair 450cc Air compressors with 2.5 gal tank, Cobra 75WXST CB Radio
Build Thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
