03-10-2012, 02:45 PM
Tire pressure: 32psi or 44psi??? HELP!!
So my 4runners specs says, manual and frame door specs, that I should run them at 32psi, but my tires specs, Bridgestone Dueler H/T a max of 44psi. For I run 100% road, no off road what so ever, until I get new tires and spacers lift.
What should I do? Its a V6 btw, no hauling....
05 SR5 V6 4x4 | DS 2.5/1.5 | BFG KO 265/70/R17 | Spidertrax 1.25" | BAMF rock sliders | Plastidip wheels/grill | LED interior swap | More to come
03-10-2012, 02:51 PM
If its 100 % on road I would run like 42 PSI. I never run the max. The door guard tells you 32 cause Its assuming you still have the stock tire. Run whats written on the tire and you'll be fine.
Matt
2005 Land Cruiser 100 Series in Galactic Grey Mica
2011 Trail Edition in Magnetic Grey
2005 SR5 4x4 SOLD
03-10-2012, 02:53 PM
I think this might be the factory tires, truck only has 49K miles on it and the tires are pretty beat up....
03-10-2012, 03:05 PM
Still, I would Go by what the tires say. Its written on there for a reason. I Personally wouldn't run the absolute max but im sure it would be ok if you did.
Matt
2005 SR5 4x4 SOLD
03-10-2012, 03:13 PM
If you put in the max the psi will become greater when you drive and your tires warm up. I keep mine at about 35psi.
03-10-2012, 03:32 PM
Real Name: Jon
Real Name: Jon
The "max PSI" written on the sidewall of the tire is the maximum cold inflation pressure for that tire. It has nothing to do with what the recommended inflation pressure is for your vehicle. The tire should be compatible with the type of vehicle it is mounted on.
Officially, you would inflate per vehicle specs. That said, I normally run mine high (42 ~ 45 psi) for the improved handling and improved mileage for on road travel. I watch the tread for wear and rotate regularly. I also run a higher load rated tire that has a max cold inflation pressure of 80 psi.
Jon
Safe travels, Jon
2008 4R SR5 4.7 great tunes and a lot of work: Build Thread
2002 Taco SR5 3.4 4x4 manual; stock ... for now
03-10-2012, 03:38 PM
Go by tire. a few pounds less than max is fine. Just keep checking your tread wear and check to make sure you are not balding the outsides of the tire (under inflated) or the center of the tire (over inflation).
03-10-2012, 04:15 PM
44psi is for a vehicle that weighs about 8000lbs. If you read the tire it'll say something like 44psi @ 2000lbs. You do NOT want to come even close to that.
The recommended pressure is 32psi. I recommend 34-35psi MAX....Anything more and you run the risk of decreased performance and uneven wear.
03-10-2012, 04:19 PM
There are two threads on this subject going on now.
http://www.toyota-4runner.org/genera...-pressure.html
and
Ask a tire engineer
The quick summery is that LTs need more psi than a P series tire of the same size and larger than stock need less psi to carry the same weight.
What does it say in the manual/door jam?
For what size tires?
And what size and type tire are you running now?
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
03-10-2012, 04:22 PM
You can't go by the tire max pressure. This is to carry the max weight that the tire can carry. A lot of people run an E rated tire and there is ZERO reason to run anywhere near the max pressure.
03-10-2012, 08:15 PM
Forget what the tire says unless there's an LT instead of P in front of the size on the sidewall (which it doesn't sound like there is). Use the door sticker pressure unless you feel like adding a little more..
If you want an expert opinion, ask a tire engineer (see Gerdos link). Better yet, read a few of the questions and answers there and you'll almost certainly see your question -- and then you'll have your answer.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
03-11-2012, 12:44 AM
Wow, another kid with his first car...
What jdkilroy said. NEVER run the stated max pressure on the tire for road use.
That said, every tire will feel different to every driver. Start out at the recommended pressure on the placard on the drivers door jamb and then increase or decrease by 2 PSI after each "test drive" until you find the one that feels the best. At 40+ PSI, your contact patch will be minimal at highway speeds so keep that in mind as you go a good bit above the recommended pressure. Most folks seem to settle on about 2-4PSI above what's recommended on the placard.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
03-11-2012, 01:02 PM
Not a kid (30) and also not my first car, just my first truck. I've never dealt with tires this big....
Anyway I ran them at 40psi yesterday and felt great on the hway. Probably will take it down to about 37-38psi since the thread its pretty bad, old tire.
03-11-2012, 02:28 PM
Doesn't matter if you're driving a Prius...or a Hummer...you use 2-4lbs over what is on the sticker on the door.
03-11-2012, 03:06 PM
Why do most people think they are smarter than Toyota engineers? With stock tires stay with the recommended pressure. You can add a little so that as the tire naturally looses air it will still not go below 32.
