Old 05-18-2021, 05:49 PM #1
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Preventative Maintenance before a 2,000 miles roadtrip with a 507,000 mile V8 4Runner
My 2008 SE V8 4Runner has 507,000 miles and the original drivetrain. I am going through everything in preparation for a 2000 mile trip from Los Angeles to Glacier National Park in Montana.
Here's a list of what I have done and if I'm missing something major please chime in. Within the last year I have done the following:
Denso spark plugs and inspected coils
All new coolant hoses, fan clutch, thermostat, and new red fluid.
Timing Belt done 2 years ago at 483,000 miles
JBA UCAs with new bushings and Moog ball joints.
LCA new ball joints and bushings.
Aftermarket CV axles and new cv axle differential seals and new fluid.
All new sway bar bushigns and links.
new oem air filter and cabin filter
new power steering (toyota atf) fluid and used GX470 pump from parts yard
All new OEM Toyota brake lines except two custom extended lines and DOT 3 fluid.
Powerstop front pads and rotors
Durobump stops
Inner and Outer Tie Rod ends
Cam tab gussets
Spindle Gussets
PML High capacity transmission pan and new Toyota WS fluid
Talon's Garage 1/4" thick aluminum transmission skid plate (on order)
OME medium 2895 rear coils
New Autozone gold battery
rear trailing arm skids
Things I want to do before I go:
rear diff fluid swap
I carry a tire patch kit and air compressor at all times plus a self jumping battery. Then the usual assorted tools.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 06:56 PM #2
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
To me, it sounds like you are about as prepared as you can be. I don't have nearly 500k miles (will be just over 200k this summer), but it looks like you've done all appropriate maintenance and preparation. Just a couple thoughts, but I'm assuming you've already though of them judging by this pretty thorough list:
Grease all driveshaft zerks.
When was the radiator last replaced? Mine was leaking around 120k and then needed replaced again around 170k.
Random hoses like transmission cooler and pcv hoses all look good? My cooler lines (the rubber ones) were sweating recently so I replaced them, and pcv hose was cracked around the connection to the pcv valve so replaced it. I would just give all hoses under the hood a good look over (but again, judging by this list I am assuming you've already though of all of this).
Cheers to those miles though, I hope to wear the 500k badge of honor one day. Enjoy the trip!
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 10:34 AM #3
I've replaced a handful of power steering and transmission cooler hoses but not all. Same with PCV hoses etc. I grease my lower ball joints and driveshafts before every weekend trip.
Old 05-19-2021, 04:52 PM #4
bbix333 bbix333 is offline
bbix333 is on a distinguished road
507,000 miles?! Bravo to you, sir!
bbix333 is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 04:53 PM #5
JAXJeremy's Avatar
JAXJeremy JAXJeremy is online now
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
half a million miles..that's pretty impressive.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is online now   Reply With QuoteReply With Quote
Old 05-19-2021, 06:00 PM #6
zig553's Avatar
zig553 zig553 is offline
zig553 is on a distinguished road
zig553's Avatar
With 507,000 miles or 815937 KMs in Canada, have you ever encountered any issues with the Secondary Air Injection Pump? Highlighted here Secondary Air Injection Pump Failure on V8's! Important!
zig553 is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 07:06 PM #7
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Glacier Park - maybe my favorite place. I agree, it seems you’ve been pretty thorough. Besides carrying some extra fluids, such as oil, distilled water, etc., my only recommendation is a AAA membership or something similar. And make sure your photo equipment is up to snuff, and bring more batteries than you need, and an extra SD card or two. Enjoy your trip!
thennen is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 10:32 AM #8
Zig553,
I have read up on that and have not had any issues. The truck has lived in CA its entire life so corrosion, rust, etc is not an issue. Not sure if that has anything to do with it or not.
Thennen,
I upgraded to the 200 mile AAA tow a few months ago in preparation. Let's hope I do not need it. I've been going to GNP for over 30 years and it's getting harder every time with the new reservations and crowds.
Old 05-20-2021, 02:56 PM #9
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
500+ on a 2008? wow! My 08 is closing in on 250k and I thought I was doing something,LOL.
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 03:26 PM #10
You got to pump up those numbers. Those are rookie numbers! Even my 1988 FJ62 Landcruiser has 315,000 miles on it.
Old 05-20-2021, 10:56 PM #11
bob3dsf's Avatar
Real Name: Bob
bob3dsf's Avatar
Real Name: Bob
I'm workin' on it...
2008 SR5 4WD
Old 05-21-2021, 03:04 PM #12
venomj venomj is offline
venomj is on a distinguished road
My 08 has only 115K ...
venomj is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 09:11 AM #13
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough Ventil8 will become famous soon enough
Real Name: Armando
Are you the original owner? I'm 200 miles short of reaching 180,000 on my 2005 that I've owned since new. I'll be in my 80s, 90s or dead before I reach 500,000
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 07:37 AM #14
NoVA_T4R NoVA_T4R is offline
NoVA_T4R is on a distinguished road
Check your spare tire for proper air pressure and possible dry rot.
Sent from my Pixel 3a using Tapatalk
NoVA_T4R is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 09:49 AM #15
thennen's Avatar
thennen's Avatar
Zig553,
Thennen,
Yeah, we got married in 1985, and honeymooned in Glacier/Yellowstone. Made it an annual thing for the next 11 years, then had kids and all that came to a halt. We finally took the kids out there in 2012, and it was a good bit different even then. Glacier is much different today - it was much more 'simple' then, and less crowded. Kinda miss the good old days.
battery , fluid , miles , rear , toyota
3rd Gen 4runner Preventative Maintenance mtbtim 3rd gen T4Rs 94 10-05-2020 10:06 AM
New Tires for a 14,000 mile roadtrip rooneyy 4th Gen T4Rs 46 08-12-2020 08:15 PM
New 4Runner Preventative Maintenance Kyngfish 3rd gen T4Rs 7 10-18-2016 05:38 PM
Anything I'm forgetting? Preventative maintenance at 200k miles... the rizz 4th Gen T4Rs 9 11-05-2013 04:04 PM
Back from a 2,800 mile roadtrip with the 4R! Ducman 4th Gen T4Rs 9 07-22-2009 11:04 AM
