Old 05-23-2021, 09:56 AM #16
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Originally Posted by NoVA_T4R View Post
Check your spare tire for proper air pressure and possible dry rot.
Sent from my Pixel 3a using Tapatalk
Yeah, this too. The valve stem on my 2001 was so deteriorated that when I unscrewed the cap, the whole thing broke off. Combined with the flat tire I was attempting to replace, I would have been screwed if I wasn't at home.
thennen is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 10:33 AM #17
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
NoVa,
I will be carrying two spares for the trip so that should cover any surprises. All less than 4 years old and in good condition.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 03:41 AM #18
pcos55 pcos55 is offline
pcos55 is on a distinguished road
Honestly Toyota designs parts with the intention of lasting their full lifespan and not needing to be prematurely replaced out of fear for catastrophic failure. If you go through and replace a bunch of parts designed to last 50 years with aftermarket stuff that might last 2 years you're doing yourself a disservice. Other than fluids and timing belt everything else should be "replace as needed". Throwing more parts at it is just money down the drain.
pcos55 is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 11:32 AM #19
Pcos55,
I normally am not as worried but with this high of a mileage I am doing my best to hedge my bets. I cannot recall where I read it but Toyota designed trucks for a 20 year lifespan before major overhauls. Given my high mileage on a 13 year old truck I was looking for helpful opinions.
Old 05-25-2021, 01:46 PM #20
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Originally Posted by randy88fj62 View Post
Pcos55,
Toyota's normal build spec is a 15-year service life with normal usage. That said, the Land Cruiser is built to a 25-year service life w/ offroad usage.
Obviously these trucks age well but a lot of us are coming up that milestone. That said, I'd be much less worried about overall mileage and more concerned with level and quality of maintenance - which you've clearly done very well.
Toyota was amused with my dad when he asked if he needed to consider an engine rebuild/overhaul on his last Tacoma. That truck had 300k miles and ran like a top when he traded it.
eleven14 is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 06:53 PM #21
Complete hearsay, Toyota has never put out those numbers.
Pcos55,
Again more hearsay. Toyota would never put out lifespan numbers because they have no relevance. They don't come with an expiration date. There are plenty of perfectly running 20, 30, 40 year old Toyotas out there with mostly original parts.
My helpful opinion is to stop wasting your money on parts that aren't needed. These trucks will last until either they're totaled, run without fluids, or rust turns them frame to dust.
Old 05-27-2021, 04:41 PM #22
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
My 2008 SE V8 4Runner has 507,000 miles and the original drivetrain. I am going through everything in preparation for a 2000 mile trip from Los Angeles to Glacier National Park in Montana.
Here's a list of what I have done and if I'm missing something major please chime in. Within the last year I have done the following:
Denso spark plugs and inspected coils
All new coolant hoses, fan clutch, thermostat, and new red fluid.
Timing Belt done 2 years ago at 483,000 miles
JBA UCAs with new bushings and Moog ball joints.
LCA new ball joints and bushings.
Aftermarket CV axles and new cv axle differential seals and new fluid.
All new sway bar bushigns and links.
new oem air filter and cabin filter
new power steering (toyota atf) fluid and used GX470 pump from parts yard
All new OEM Toyota brake lines except two custom extended lines and DOT 3 fluid.
Powerstop front pads and rotors
Durobump stops
Inner and Outer Tie Rod ends
Cam tab gussets
Spindle Gussets
PML High capacity transmission pan and new Toyota WS fluid
Talon's Garage 1/4" thick aluminum transmission skid plate (on order)
OME medium 2895 rear coils
New Autozone gold battery
rear trailing arm skids
Things I want to do before I go:
rear diff fluid swap
I carry a tire patch kit and air compressor at all times plus a self jumping battery. Then the usual assorted tools.
I didn't see anything regarding the transmission fluid. Have you changed it ever? I know that the manual states "lifetime" transmission fluid, but the word "lifetime" is defined as 7 years in California.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 05:13 PM #23
Item 16:
"PML High capacity transmission pan and new Toyota WS fluid" New screen filter/o-ring too.
Old 05-27-2021, 08:10 PM #24
Real Name: Skip
Real Name: Skip
Item 16:
With the new pan, how are you checking the fluid level to insure it has the correct amount?
2004 Limited V8
Old 05-28-2021, 06:43 AM #25
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
Durobump stops
Cam tab gussets
Spindle Gussets
These will bolt on and the bearing is in there. Amazon.com : bearing assembly for 4runner
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 08:26 AM #26
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
500k+ on a '08 is nuts. I only have 86k lol.
Glad to hear shes still going strong!
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 02:48 PM #27
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
Originally Posted by venomj View Post
My 08 has only 115K ...
Oh, to back in the 100's.... Like a brand new car! LOL
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 08:06 PM #28
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
Back in my day, blowing a tranny meant you had car trouble.
meltdowner is offline   Reply With QuoteReply With Quote
Old 07-01-2021, 12:31 AM #29
joec500 joec500 is offline
joec500 is on a distinguished road
From my research on toyota trucks it seems if maintenance is followed and you don't live in an area with a lot of snow/salted roads, these cars can run 500k miles pretty easily.
My other car is a Porsche 911 and older 996 turbos are hitting 300k miles on original motors and trannies. The owner stayed on top of all maintenance obviously, but those cars are also built bullet proof. Maintenance goes a loooong way.
joec500 is offline   Reply With QuoteReply With Quote
Old 08-06-2021, 07:46 PM #30
gloch gloch is offline
gloch is on a distinguished road
This is an inspiration for me. I just ticked off 250k on my '03 V8. Your list of maintenance items is extensive and represents goals for me. Did you do these yourself?
gloch is offline   Reply With QuoteReply With Quote
battery , fluid , miles , rear , toyota
3rd Gen 4runner Preventative Maintenance mtbtim 3rd gen T4Rs 94 10-05-2020 10:06 AM
New Tires for a 14,000 mile roadtrip rooneyy 4th Gen T4Rs 46 08-12-2020 08:15 PM
New 4Runner Preventative Maintenance Kyngfish 3rd gen T4Rs 7 10-18-2016 05:38 PM
Anything I'm forgetting? Preventative maintenance at 200k miles... the rizz 4th Gen T4Rs 9 11-05-2013 04:04 PM
Back from a 2,800 mile roadtrip with the 4R! Ducman 4th Gen T4Rs 9 07-22-2009 11:04 AM
