Old 05-27-2021, 04:34 PM #1
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Battery 4.0 V6
Hello guys
I have been told by the importer that I should expect my truck to have a flat battery when it arrives.
The "Choose your vehicle" selectors over here of course don't have it as an option.
It looks like we use different battery terminology/codes over here.
Would any of you mind sending me the measurements of the casing and between the terminals of your battery so I can order a new one ready?
Or, if you are familiar with our codes please let me know what I should buy.
Thank you
SurferUK is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 06:46 AM #2
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
Batteries don't last over 4 years in a hot climate. Just watch them and get a new one at a battery and tire shop.
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 08:02 AM #3
wsgoat's Avatar
wsgoat wsgoat is offline
wsgoat has a spectacular aura about wsgoat has a spectacular aura about
wsgoat's Avatar
Try and get a Panasonic battery if you can....the Panasonics are OEM on the 4Runner and one of the better batteries available imo. I have never had an issue with my battery going flat, even after prolonged storage (6-months), so you might be pleasantly surprised when you take delivery.
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
wsgoat is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 05:31 PM #4
SurferUK's Avatar
SurferUK's Avatar
Could you tell me what type of battery yours has please? (Assuming you have a 4.0 V6!)
These were never officially imported here so I will see if the FJ Cruiser battery is a good enough replacement (Same engine)
Old 05-29-2021, 11:29 PM #5
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Factory size for 4.0 is 24F. Wondering if you can find it under "Hilux surf", pretty sure that's what it's called in Europe
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 02:23 AM #6
Harlock's Avatar
Harlock Harlock is offline
Harlock will become famous soon enough
Harlock's Avatar
You don't state where you are or what vehicle you're importing. But I'm assuming you're in the UK and are importing a 4th gen 4Runner. If this is the case, you'll either have a BCI standard Group 35 or Group 24 battery. Group 35 batteries are approximately 230 mm L x 175 mm W x 225 mm H. Group 24 batteries are about 25 mm narrower in width. In Europe, a Group 35 is often known as a Q85. Hope this helps.
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
Harlock is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 12:24 PM #7
SurferUK's Avatar
SurferUK's Avatar
Thanks mate, yes we call it the Hilux Surf here, but we never the 4th gen here, or petrol/gas engines. All that's available without private import (As I am doing) are ropey old late 90's diesels.
Old 05-30-2021, 12:24 PM #8
SurferUK's Avatar
SurferUK's Avatar
That's perfect mate thank you It is a 4.0 V6
4th Gen T4R Picture Gallery
battery , casing , measurements , sending , terminals
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
Anyone using the $26 Summit Racing SUM-G1201 battery tray for 31M battery? jicko 5th gen T4Rs 3 04-27-2015 12:24 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
SS006-07 08/11/2007 Battery - Absorbed Glass Mat Battery (AGM) Information CBR_GUY_IA TSB 0 07-12-2009 09:30 PM
