Old 01-01-2017, 12:28 PM #1
kevin1285 kevin1285 is offline
kevin1285 is on a distinguished road
What should my next steps be? P0430 and P0420
I have an 06' 4runner with 300k miles. I'm getting these two check engine codes, Catalyst Efficiency below normal in bank 1 and 2. I've reset it a couple times by disconnecting the negative battery cable, but it always comes back within 20 miles and now I need to pass inspection. I've been reading threads on this, and can't really come to a conclusion on my best course of action. At first I thought I should try changing the 02 sensors, but it seems faulty 02 sensors have their own error code. Is that where you all would recommend starting? Replacing the sensors? Really hoping I don't need a new cat.
kevin1285 is offline   Reply With QuoteReply With Quote
Old 01-01-2017, 12:34 PM #2
rjb75 rjb75 is offline
rjb75 is on a distinguished road
I would start w the oxygen sensors-much cheaper. If you wind up changing the cats too, you'll want new sensors to go along with them.
'16 SR5 Magnetic Gray Metallic
rjb75 is offline   Reply With QuoteReply With Quote
Old 01-01-2017, 10:16 PM #3
zonianbrat's Avatar
zonianbrat zonianbrat is offline
zonianbrat is on a distinguished road
zonianbrat's Avatar
I went through this recently. I had the 0420 code usually but then the 0430 came in a time or two. The CEL comes on when the cats are reading some ridiculous number of like below 95% efficient. After knowing this I took my temp gun and got the truck to running temp and starting taking temps on the cats. The one on the driver side just under the driver seat had an inlet of close to 500 degrees but outlet was only 230. I am not a mechanic but I believe that one is the culprit as all the other ones were close to 500 going in and coming out. I ran high octane fuel with octane booster and ran it hard down the interstate on the way to the emissions place and cleared the code with my phone before going in. The truck passed and was well within state limits for Colorado. Lights came on like 30 miles down the road again. Just sharing my story and letting you know that just because your CEL is on with the 0430/0420 code it doesn't necessarily mean your truck is below state emissions standards. It's worth a shot to test it and verify it fails before spending lots of cash to throw parts at it that it really doesn't need. Good luck and keep us updated.
zonianbrat is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 12:26 AM #4
preacher35's Avatar
preacher35 preacher35 is offline
preacher35 is on a distinguished road
preacher35's Avatar
Kevin, I JUST went through this the past 48 hours. My '05 was throwing P0430 (bank 2 cat converter). I purchased a new downstream O2 sensor ($90.00 Bosch), installed it (took 4 minutes to do), unplugged the battery to reset the ECM, and drove it for 105 miles. No more CEL/VSC Trac lights. I am cautiously optimistic that this was the problem.
You should purchase at least ONE downstream O2 sensor and try it on both sides and have someone with an ODBII scanner check to see of the codes cancel out. Hopefully, this will resolve your issue!
Preacher
2005 Sport Edition V6 / Toytec Ultimate 3" lift / Light Racing UCA's / 17x9 KMC Hoss wheels / 285/70 17 Goodyear Duratracs / Gibson cat-back / black headlights / HID's / Shrockworks bumper / Rola Vortex roof basket / LED interior swap / Emelianenkov's gauge cluster LED swap /
preacher35 is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 02:10 AM #5
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
These two codes indicate the cats are dirty, plain and simple. Cats get dirty and eventually get more and more clogged. They need to be cleaned which is something most of us are not willing to do so we end up replacing them. They can be washed and cleaned but the PITA factor is just too high to do this. O2 sensors have their own code when they start to fail, which is usually related to their heaters.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 04:31 AM #6
preacher35's Avatar
preacher35's Avatar
No, not necessarily. As I stated in my earlier post, mine was throwing P0430 and it turned out to be the downstream O2 sensor. If the downstream O2 sensor is faulty, it is not going to be able to report accurate catalytic converter data back to the ECM, or no data at all. This will result in a P0430 or P0420 code. I am not the only one on this forum that has had this same issue and resolved it with a simply O2 sensor replacement. But yes, it COULD be his cats. So why not try the cheaper, easier option first?
Old 01-02-2017, 10:13 AM #7
This confirms the conundrum I'm facing, seems it can be the 02 sensor or it can be the cats. I'll try the sensor first and go from there. I figure it's probably not a bad thing to do anyways since these are the original sensors with 300k miles. State emissions requirements are a pain in the ass.
Old 01-02-2017, 12:11 PM #8
That's a good plan, start with the least painful/cost items first.
Old 01-02-2017, 12:22 PM #9
J-Roc's Avatar
J-Roc J-Roc is offline
Real Name: J
J-Roc will become famous soon enough J-Roc will become famous soon enough
J-Roc's Avatar
Real Name: J
I live in southern Ontario Canada...Required to do an emissions test every 2 years. I have had these 2 codes for aprox 6 months now and my e-test was due a while ago. Dreading the worst and assuming I was going to have to sink at least a thousand or two into new CATs just to get relicensed for the year. Took it into my shop for the test and bad news. Even drove around for a few weeks with expired tags assuming I was going to have to pay lots when it came time to passing.
Turns out, our laws for these tests are ridiculous...Since it would cost over $500 to make my truck "pass" the test...I was given a "conditional pass" and had to just pay for the failed test itself.
I know this still doesn't solve the issue of the codes and what's wrong, and I do know that one of my CATs is bad. At least I can still drive legal for the next two years before this comes up again.
Check the laws in your area, and it may buy you some more "saving up money" time to fix the real issue. O2's or CATs.
2013 Blizzard Pearl Ltd/14’+Tail Light Swap/Anytime Backup Cam/275-55-20 Wildpeaks/TailAsTurn/Triton V3 Switchback Fronts/5100’s/1” Eibach Rear Coils/CaliRaised Ditch Pods&Brackets
Sold-2005 V8 Dorado Gold Pearl Ltd
Retired-1996 Evergreen Pearl Ltd
J-Roc is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 02:54 PM #10
Anybody ever tried removing the cat and cleaning it?
Old 01-02-2017, 06:55 PM #11
I might be attempting that on the GF's '08 limited V8 this spring. These cats aren't easy to clean by the way they're attached to the down pipe.
Sent from my SM-G920V using Tapatalk
Old 01-02-2017, 08:28 PM #12
Anteupp's Avatar
Anteupp Anteupp is offline
Anteupp is on a distinguished road
Anteupp's Avatar
went through the exact same problem with my tacoma and Honda, save yourself the headache, the few hundred if not thousand dollars and get yourself a set of spark plug non foulers from autozone and do the "non fouler mod" explained here.
https://www.youtube.com/watch?v=wcDPAfz10Io
Don't double up the spacers like this guy did, one will do. Guarantee you pass especially if your state doesn't test the actual exhaust gases coming out of the tailpipe, if those are above your states accepted pollution levels and they test those you're SOL. Good luck
Anteupp is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 08:29 PM #13
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Much cheaper to replace all 4 ! Although the a/f sensors are a nightmare , well worth it to change same time ! Or spend money on the URD plug & play rear sensor simulator ! Very rarely cats why peps be stealing off Tacos & 3rd gens Platinum in them !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 08:36 PM #14
^^ this is much CHEAPER !
Old 01-03-2017, 10:45 AM #15
I ended up buying two of these
https://www.amazon.com/O2-Sensor-Spa...+sensor+spacer
Definitely seems to be the way to go. From what I've read this works about 90% of the time. We shall see.
P0420, P0430 and O2 simulator alia176 4th Gen T4Rs 1 07-20-2016 11:46 AM
Codes P0420 and P0430 (Help!) BtownRunner 4th Gen T4Rs 1 12-29-2014 03:40 PM
CEL 2 codes P0420 P0430 kacper 4th Gen T4Rs 6 11-20-2014 04:13 PM
P0420 & p0430 4derekyrunner 4th Gen T4Rs 3 02-26-2012 11:49 AM
P0420 & P0430 Codes, When will it end??? a77boy Problems & Warranty Issues 16 01-19-2011 12:05 AM
