Real Name: brian
Real Name: brian
Finding that might be difficult. The only way to rule any area out is remove the whole interior. There are so many places a critter could hide. First look for any brown drips anywhere, headliner, on trim pieces etc. If you do see it then you have narrowed the down the area. Critters usually have a specific place they always go. If not then you will have to pull everything out and look for nests, dead critters, poop. If found clean everything thoroughly. If it's in the carpet, toss it, the smell will never come out.
My '08 had critter damage before I bought it. The entire interior harness was replaced, they chewed the seat belts, ate the leather rear lower seat. The only thing fixed was the harness. I was tracing a bad ground and I found whole almond shells in the rt kick panel, the metal area. There were 25 of them. The cabin filter had a nest in it( pic attached ). Critter damage can also lead to mildew and mold. It's not healthy.
When I was an appraiser I had to look at a '09 rx400. Said to have " fluid damage". When I got there I could not get near the car the smell was soo bad. Come to find out the owners had a special needs daughter who always peed in her car seat. That pee got into the hybrid battery, seats, carpet, battery well. I had to total it because it would never clean up and it was not healthy to be in. It rusted the metal.
Try to find your issue as quick as possible, it will only get worse, especially if you are in a warm climate. If it's too expensive you can get insurance involved, it will be covered under your comprehensive.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
