Old 05-23-2021, 02:59 PM #1
cice cice is offline
cice is on a distinguished road
Talking Leak Solved... it WASN'T the sunroof!
For the past several years, the passenger side floorboard is always wet after it rains. At first, I thought it was the sunroof, so I used the weed wacker line idea and cleaned out the drains. Still wet. I then went a little crazy with the caulk and sealed up everything that looked like it might leak water when driving in the rain. Still wet. Finally, I gave up and took it to a shop (in fairness to myself the timing belt had also slipped a tooth). They said the leak was the sunroof drains, and they had cleaned them out. Last week it rained like crazy and the floor board was still wet! I finally decided to catch the leak in action and pulled up the carpet, etc, put a towel where I thought the leak would be, and waited for the rain. When it rained I sat in the car and saw this:
Well it certainly wasn't the sunroof! I took off the plastic cowl cover and discovered the culprit! The air intake for the A/C system!
The cracked rubber on the cowl cover was letting water in, and it was getting into the A/C air intake.
It looks like the cowl cover has two trays to divert water away from the intake.
In the case of mine, one looks like it is supposed to "hook" under the windshield glass. Sadly, all the clips to hold the cowl cover to the windshield were broken. I decided to brute force and just seal up the rubber with some black silicone.
In retrospect, I think if I had put the cowl cover back on at an angle it might have realigned the water tray to be under the windshield and catch/divert the water leaking through the rubber seal. Oh well, it poured rain yesterday and no more leak! Hopefully this helps someone else, I'm surprised more folks don't have this issue... of course the first reply to my post might be a link to a whole thread on this topic.
Leak Solved... it WASN'T the sunroof!-img_3155-jpeg  Leak Solved... it WASN'T the sunroof!-img_3163-jpeg  Leak Solved... it WASN'T the sunroof!-img_3164-jpeg  Leak Solved... it WASN'T the sunroof!-img_3162-jpeg
cice is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 12:54 PM #2
Rocket3004 Rocket3004 is offline
Rocket3004 is on a distinguished road
nice investigative work! I wouldn't have guessed that
Rocket3004 is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 02:10 PM #3
chrisbagnell's Avatar
chrisbagnell chrisbagnell is offline
Real Name: Chris
chrisbagnell will become famous soon enough
Real Name: Chris
good find, also check to make sure your seam sealer isn't cracked while you have the cowl off, **WATER LEAK** 4Runner Unusual Footwell Water Leak Solution
chrisbagnell is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 11:50 AM #4
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
could this happen due to improper windshield replacement?
rwh963 is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 09:56 PM #5
HaikuHasselhofff HaikuHasselhofff is offline
HaikuHasselhofff is on a distinguished road
A/c water leaking
I have the same type of problem I think. I have water coming from somewhere in the dash above the a/c drain tube. How do you remove the cowling from the windshield? I had the windshield replaced recently, but the problem started before that. Sometimes the water is gone and then it comes back. I can hear the water moving around too. Stinky smell in my car is building up. 2016 stock 4Runner with 67k miles.
HaikuHasselhofff is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 12:54 AM #6
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Have someone stand outside with a garden hose while you investigate inside. Do not use high pressure from the hose. Straight out if the hose to recreate heavy rain. Have them move from place to place slowly until you narrow down the water intrusion.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 09-01-2021, 05:02 PM #7
baby#yota's Avatar
baby#yota baby#yota is offline
baby#yota is on a distinguished road
baby#yota's Avatar
I have a similar issue but I have a wet drivers carpet. Still trying to figure out what it could be. Your post isn’t exactly my situation but the coweling deserves another look on my truck. Water leaks are by far the most frustrating thing to deal with on cars. Especially ones you can’t track down easily!
baby#yota is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 12:32 AM #8
PNWToy4Rnr PNWToy4Rnr is offline
PNWToy4Rnr is on a distinguished road
Not sure if this is helpful but I had to replace the front window side trim piece. That trim piece is held in place by a part that fits into 3 holes that go into the outside of the A-pillar. If any of those are broken that might be letting water in.... Just a thought. the part i'm refering to is 75548a/75549b in the link. You can kind of see the three pins that go into the body in the illustration.
https://parts.toyota.com/images/part...a1_751555H.jpg
PNWToy4Rnr is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 10:12 AM #9
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
i never thought of this but good info just in case it happens to my 4runner, i know where to look. thank you!
4r-4ever is offline   Reply With QuoteReply With Quote
cover , cowl , leak , sunroof , water
4th Gen Sunroof - stuck in open position/grinding motor sound - SOLVED! thenuka 4th Gen T4Rs 6 09-02-2022 04:26 PM
Help! Sunroof Leak! b.moore2011 3rd gen T4Rs 15 09-02-2022 10:10 AM
Sunroof rattle solved! rockwall 4th Gen T4Rs 21 07-13-2022 10:19 PM
SOLVED: Floor board leak...Roof channel issue leaks trublucali 5th gen T4Rs 2 05-21-2020 07:43 PM
Solved: Hard vacuum leak under DECELERATION STI_MECE 3rd gen T4Rs 77 03-04-2020 08:02 AM
