Originally Posted by mott768
finally found the actual wire harness layout for the urban runner with tom tom HU. You can see how different it is from normal 4runners. Can someone help me install the maestro RR and T01 wire harness adapter?
going to need to hardwire or disect the t01 harness. its not as plug and play as you think, the odb port is plugged in, but you still need to hardwire the included harness of the maestro so you dont hack up the t01 harness.
i think the wire color might be the same as i posted on the other thread. use that as a guide.
take a pic of the original maestro harness, the colors of the wire.
