Old 01-10-2014, 11:27 AM #1
ID4Runner ID4Runner is offline
ID4Runner is on a distinguished road
03 4Runner Multi-Information Display Issues
Hey guys,
I've got a problem, no it's not the backlight, I've replaced those before (how damn easy is it to take that panel off?! It's awesome)
Today on my drive to work, I look down and my Multi Info Display is lit, but all that's showing the time. Also all 3 of the climate controls are black. I had the control on Auto before and I can hear the air blowing. So that's working.
I looked through the manual to see if there is a fuse, can't seem to pin point which one controls that unit.
I also read a couple other threads and one hits the nail on the head of what I'm talking about, although he states the dealership told him it was the AC Control Booster, except it's blowing air, as though it's still on Auto, seems like it's just the display and lights.
Ac, multi information display went out, and more.m
It's g4run whom I'm referencing.
Any help would be awesome. Thanks guys, I'll attach a pic to help.
03 4Runner Multi-Information Display Issues-034runner-jpg
ID4Runner is offline   Reply With QuoteReply With Quote
Old 01-10-2014, 01:09 PM #2
Martinjmpr's Avatar
Martinjmpr Martinjmpr is offline
Martinjmpr will become famous soon enough
Martinjmpr's Avatar
OK, I have a couple of questions for you:
First off, don't be insulted, but have you tried cycling through the "modes?" If so, does anything change?
Second, you say the air is blowing but does the climate control seem to be working? IOW, can you push up on the temp and it gets warmer, push down and the AC kicks in, etc? Can you change the blowers to the different modes (feet, feet/face, defrost, etc?) Can you change the blower speed?
If so, it seems like your computer is working but the LCD display is not. Unfortunately, I don't know of any way to fix that other than to replace the whole HVAC control panel, which I think can be expensive (though I think you can find one in a junkyard for a lot less than what Toyota will hit you for.)
That's the bad news, I guess, but the good news is that if your HVAC is actually working, you don't have to fix it right away, you can wait until you can afford the parts.
Martin AKA Zapp Branigan - No longer a 4runner owner!
Martinjmpr is offline   Reply With QuoteReply With Quote
Old 01-10-2014, 01:48 PM #3
Martin,
I wish that first idea was the one, nothing happens when I cycle through 'modes' or ever press and hold 'reset'
I couldn't tell if the blower was going this round as I think it's on Auto and it's cold out so it's not warm enough to kick on.
All the lights are off on the HVAC system. I pulled all the fuses I could that so much as mention they are associated with the HVAC system.
Also I did play with all the buttons to see if that changed anything and it didn't. Seems like no signal is making it to the computer from the unit.
I'm hoping maybe there is a short somewhere? And yeah, seems like you might be right on the HVAC system. I'm going to pull that unit off at lunch and see if I can make heads or tails of it, doubt it but worth the try.
Old 01-12-2014, 01:07 AM #4
Martinjmpr's Avatar
Martinjmpr's Avatar
Sucks to say it but it seems like the HVAC control unit is fried. Expensive to buy a new one (I want to say around $1000) but you should be able to find one from a wrecked vehicle that works.
Looks like you have a limited so that may narrow your choices. I doubt that you could swap an SR5 unit into the limited (though I guess you could always try.)
Old 01-12-2014, 05:37 AM #5
awdjunkies's Avatar
awdjunkies awdjunkies is offline
awdjunkies is on a distinguished road
awdjunkies's Avatar
If you have to resort to purchasing a whole unit, here is one at one quarter of the price 2005 Toyota 4Runner Air Conditioning Control Assembly HVAC | eBay
PS: Not Mine.. And like Martin suggested.. trying to swap
PPS: Heck!! EVEN A BETTER PRICED ONE!! http://www.ebay.com/itm/2005-Toyota-...91021234787%26
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
awdjunkies is offline   Reply With QuoteReply With Quote
Old 01-13-2014, 01:47 PM #6
Thanks for the help guys, one more odd thing, the rear wiper doesn't work either... strange that that would run through that unit somehow.
I do have one more thing I'm going to try, my GF has a '08 Limited, so I'm going to swap out her's and see if it works in mine, that should tell me if it's the unit or maybe a relay?
Thanks again, I'll keep you updated.
Old 01-15-2014, 10:41 PM #7
Ok, so now it gets more interesting. I tried my gf's control panel and it didn't work either. I then took mine and it worked in hers.
So I started with relays, using the good relays from the other 4runner, couldn't seem to figure it out. The odd thing is that the rear wiper isn't working either. Is there a relay that controls both?
I'm lost right now. Happy to find it's not the panel. But starting to get worried it's something more...anything I should check?
Old 01-16-2014, 07:51 AM #8
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
Originally Posted by ID4Runner View Post
... my Multi Info Display is lit, but all that's showing the time. Also all 3 of the climate controls are black. I had the control on Auto before and I can hear the air blowing. So that's working...
It's almost as if the controls are in ACC mode (when the key is turned but ignition isn't on) even though you are in ON mode. Not sure how to help but have attached the '04 wiring diagrams for reference. Maybe there is a problem common fuse between the controls and the rear window body ECU?
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 02-20-2014, 12:32 AM #9
Matt fe2o3 Matt fe2o3 is offline
Matt fe2o3 is on a distinguished road
My 06' has half the display light going out (dim) for a while (original replaced under warranty, so I guess they only last so long.
How on earth do you get that bugger out of the dash console?
Matt fe2o3 is offline   Reply With QuoteReply With Quote
Old 09-28-2014, 10:56 PM #10
kpl's Avatar
kpl kpl is offline
kpl is an unknown quantity at this point
kpl kpl is offline
kpl's Avatar
did you guys find a solution? My central display is out and the turn signals also.
Kevin
03 SR5 4WD V8
kpl is offline   Reply With QuoteReply With Quote
Old 09-28-2014, 11:08 PM #11
preacher35's Avatar
preacher35 preacher35 is offline
preacher35 is on a distinguished road
preacher35's Avatar
Forget getting a response from this guy. He's only done four posts in nine months. No, he's not coming back until, maybe he has another problem that requires our help.
2005 Sport Edition V6 / Toytec Ultimate 3" lift / Light Racing UCA's / 17x9 KMC Hoss wheels / 285/70 17 Goodyear Duratracs / Gibson cat-back / black headlights / HID's / Shrockworks bumper / Rola Vortex roof basket / LED interior swap / Emelianenkov's gauge cluster LED swap /
preacher35 is offline   Reply With QuoteReply With Quote
Old 10-01-2014, 12:14 AM #12
kpl's Avatar
kpl kpl is offline
kpl kpl is offline
kpl's Avatar
Found the IG1 15A fuse blown under the dash. How the directionals, the display, etc are interrelated are beyond me, but everything works now
Kevin
03 SR5 4WD V8
Old 11-17-2015, 09:57 PM #13
Jbrannski Jbrannski is offline
Jbrannski is on a distinguished road
This was my solution as well. I hauled a horse trailer a short distance at night. Parked it that night and unhooked the trailer. The next morning I had no a/c controls or display, no turn signals, no cruise control, and gear light indicators did not light up. I checked every fuse except the ECU and IG1thinking they would have nothing to do with it. Well IG1 15A blown.
Jbrannski is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 11:25 PM #14
Athalho Athalho is offline
Athalho is on a distinguished road
Similar Issue
Nothing but the clock is working on the climate control panel. However, the A/C is running on it's most recent position...So at least I have the defrost setting going on cold air. Did anyone else find a solution to this? I am guessing I need to replace the panel but maybe it is something else also?
Athalho is offline   Reply With QuoteReply With Quote
half black multi information LED display tcpoob 4th Gen T4Rs 30 01-22-2017 09:50 PM
Ac, multi information display went out, and more.m vicperdido 4th Gen T4Rs 12 01-12-2015 04:01 PM
How can the Multi-Information Display be seen better during the daylight hours jow 4th Gen T4Rs 4 05-06-2013 08:39 AM
03 4runner, multi information display captain204mike 4th Gen T4Rs 3 11-08-2008 02:34 AM
Multi - information display gledhill 4th Gen T4Rs 3 10-06-2008 09:54 PM
