I tow a 4200lb dry weight trailer with mine, it has a dual axle with electric brakes. My 06' V6 has the slightly bigger 5th Gen brakes, a UHAUL ATF cooler and a WDH.
You will do fine but I recommend a stiffer spring or a Timbren setup in the rear and the V8 hitch. If you can't find the hitch, buy one from UHAUL or online since the crossmember hitch is way stronger and meant for a WDH setup.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
