03-20-2016, 01:36 AM
I know, another Poor gas mileage thread.
Guys I purchased a 2007 V6 4runner 4x4..
I took it home and averaged 18.5 on the first trip..
since then I have done everything that could be done to improve mileage or at least maintain it you would think (new plugs, clean MAF, carbon filter delete, new air K&N filter, premium gas, fuel injector treatment, switched to synthetic oil, new serpentine belt, new clutch fan (wasn't turning off), tranny flush, differentials/transfer case have brand new oil) NO lift, 1.5 inch allpro spacers, stock sized tires..
the last 4 fill ups I averaged 16.1 MPG.. Computer says 18.5 but is wrong.. NO CEL..
from what I have read..
-it could be a dragging front caliper, car doesn't pull....
-it could be an exhaust leak
-it could be a bad O2 sensor with no code?
any other suggestions?
03-20-2016, 01:41 AM
the last 4 fill ups I averaged 16.1 MPG.. NO CEL
Have you taken it to a dealership? Somethings definitely not right though.. Put a lift and larger tires on a 2wd and am getting about 20/21 mpg.. Hope you're able to figure out what's causing your mpg to be so low. Sorry I couldn't help on the actual cause.
08 SR5 2WD 4Runner / LED Interior / Map Light & DRL Mod / Full Audio Overhaul (Pioneer 5100, F Kicker 6x9 Comps, R Kicker 6.5 2Ways, Hidden Kicker 8" Comp, Hidden Alpine Amp) / Custom LED Gauge Cluster & HVAC / SoCal LEDs CanBus 6000K Headlights / CSJUMPER Switchback DRLs / Bilstein 5100 (.85 Setting) / 2010 4X4 FJ F&R / 265/70/17 BFG KO2 / Ebay 1.25" Wheel Spacers F&R
03-20-2016, 04:18 AM
I really don't want to start another thread either, but I'm having the same problem. I originally was getting 19-21 mpg. Now, I'm getting 15-18. I don't know what's going on. I haven't done all the same maintenance as OP, but I guess I'll have to start.
03-20-2016, 08:56 AM
Registered User
Registered User
I've been thinking about this too for a long time and nobody were able to answer it. I'm supposed to replace my ect sensor to see if that would work but did have a chance to replace it due to stuffs in the way.
Have you tried the ect sensor? If you have a v6, it's located next to the firewall in between the cylinder.
03-20-2016, 09:18 AM
Real Name: Joey
Real Name: Joey
Not sure if this helps, but I recently had a new gas tank, filler neck, and charcoal canister installed and saw a big gain in mileage. 05 4wd v6
2005 Sport Edition 4WD, 2" Spacer lift, DIY Cargo box, Dual battery setup, Cobra CB Radio, Kenwood Double Din DVD Headunit, Backup Camera, K & N Intake, Method 17" Wheels, 5% Tint all around, Foglight "ON" Mod, TPMS light bypass mod
03-20-2016, 09:22 AM
Registered User
Registered User
Good info. What did you have before and after?
03-20-2016, 09:41 AM
Could be worse I get 11-13mpg consistently with no hints as to what's causing it. I've done everything with my limited knowledge on motors that I can. Only two cents I can throw your way is if you recently did your plugs, check the gap on them. I did mine recently and found that I had to adjust the gap on the Denso's I put in
03-20-2016, 01:11 PM
whats confusing me is why the vehicle says I'm getting 18.5 on the display, but when i check manually, by trip distance since last fill up divided by gallons used to fill up equals 16.1..
So the vehicle ecu thinks its giving me 18.5 MPG, but why is the million dollar question.....
03-20-2016, 01:27 PM
My MPG consistently says around 15.5-16.5, and I have 17 inch OEM 5th gen wheels with 265/70/17 tires and a mild Bilstein/FJ Springs lift. I have calculated it manually but that calculation was something ridiculous like 14. Is this typical or should I expect to be getting a higher MPG?
Current Vehicle: '03 Limited V8 W/ CBI Front Bumper, OME 886 w/ Bilstein 5100, Total Chaos UCA's & more
03-20-2016, 02:18 PM
Ditto. New plugs new air filter, properly inflated tires, the list goes on. I filled up today 13.8....WTF. I drive like an old woman. I will say that about 95% of my driving is 45mph or lower, all city. Could that be it?
2007 SR5, V6, Shadow Mica, Toytec Boss, 265/70/17 Terra Grapplers, Rocky Road Super Sliders
03-20-2016, 02:38 PM
Sounds like we might have to settle with the fact that our trucks just don't get great mpg.
03-20-2016, 02:44 PM
My town hardly has speed limits over 40. I don't often have a full tank used in town so I've never really been able to tell how bad my city mileage was, but I recently did and it was god awful. Like high 14's, low 15's mpg.
I don't know if you guys use fuelly, but if you haven't heard of it it's a good gauge on seeing what other people get for MPG.
http://www.fuelly.com/car/toyota/4ru...=&submodel_id=
The only crappy part is I see many people getting 18+ mpg and I'm on the lower end of the scale. Maybe it's caused by winter gas and high elevation. That's the only thing I can think of.
03-20-2016, 04:47 PM
could you please elaborate on this? why did you replace the gas tank?
White 2017 TRD Pro
Black 2007 Limited V6 4WD - Sold
03-20-2016, 08:41 PM
I think people who report 18+ mpg only drive down hill.
Yesterday I drove 160 miles in my 2006 V8 that included mixed interstate (65-70 mph), rural highway (60 mph), and gravel and dirt roads (20-40 mph) and I averaged 17.7 mpg. Almost 18 mpg! Computer said 19.1. This is about as best I can hope for. It is interesting, I also have a 2006 Tundra with the same engine and I have gotten up to 20.5 mph in it. In town I average 12-14 mpg in both vehicles.
2006 Sport Edition V8
03-20-2016, 08:49 PM
The problem for me is that I have similar mpg in a v6.
