Old 06-06-2021, 03:21 PM #16
5280fre 5280fre is offline
5280fre is on a distinguished road
What are the specs/dimensions of the M12 bolts?
2005 4Runner v6, 160k and going...
5280fre is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 05:17 AM #17
Jeremy_A's Avatar
Jeremy_A Jeremy_A is offline
Real Name: Jeremy
Jeremy_A has a spectacular aura about Jeremy_A has a spectacular aura about
Jeremy_A's Avatar
Real Name: Jeremy
M12x1.25x 30-45
They can be tricky to find. 1.25 isn't that common in m12. Took me 3 or 4 different lowes/home depots to find them.
2007 4Runner Sport 4x4
CoastalOffroad-Smittybilt-4xInnovation-RCI-BajaRack-SPC-ICON-Nitro4.88-EatonElocker-CVJ--PolyPerformance-Method-MickeyThompson⁹-AFE-Urd-Gibson-SprintBooster-Weathertech-Pioneer-Infinity-DiodeDynamics-OPT7-HiLift-Coverking
Build thread:
https://www.toyota-4runner.org/4th-g...ort-build.html
Jeremy_A is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 11:37 PM #18
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
You will likely have gaps, just try to even out gaps as much as possible. Light tacks so you can bend pieces to align them and worse case cut tacks.
Pic 1- part 7s welded on. Use a bungie to pull up on ends
Pic 2- bevel top edge, tack part 9 on
Pic 3- bevel top edge tack part 10 on
Pic 4- bevel top edge, tack part 11 on
Pic 5- tack part 12
Pic 6- tack part 13, pay attention to how it goes
Pic 7- tack part 14
Coastal offroad front bumper build guide-20210610_152557-jpg  Coastal offroad front bumper build guide-20210610_153824-jpg  Coastal offroad front bumper build guide-20210610_153831-jpg  Coastal offroad front bumper build guide-20210610_163241-jpg  Coastal offroad front bumper build guide-20210610_163245-jpg  Coastal offroad front bumper build guide-20210610_163249-jpg  Coastal offroad front bumper build guide-20210610_163253-jpg
Build thread:
Old 06-19-2021, 04:14 AM #19
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
Next steps are to remove the bumper and start welding. Do series of stitches on back. You done need to weld it all the way. I do weld the whole winch area though.
I then turn my welder down a little for the front side as I want the weld to be small and minimize grinding. I do straight stringer beads in the seams. If you have small seams I suggest opening those up with a cut off disk. You only need to cut a slot half way through, this will keep from have seam cracks show after grinding.
Learn to grind, it is important. There are videos, but basically use a low angle and continuous motion, be careful not to dig or only grind a small area.
After grinding I use a palm sander to really get things smooth and my edges crisp.
Coastal offroad front bumper build guide-20210617_160304-jpg
Build thread:
Old 06-19-2021, 04:18 AM #20
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
How to do the tubing.
You have a couple options...
If you are doing just the center tube you can set it pretty vertical... center it, place it forward on the bumper as much as possible. Then tack just the front. Now open your hood... it will likely touch... bend the tube forward for clearance and add some tacks.
I find that in order to weld tube and have it look good, if you do overlapping tacks it gives a clean look and is easier. It's super hard to run a bead on the inner area. This method will look better.
Coastal offroad front bumper build guide-20210618_125627-jpg  Coastal offroad front bumper build guide-20210618_125545-jpg
Build thread:
Old 06-19-2021, 05:23 PM #21
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
How I palm sand. Flat surface to flat surface. 40 and 60 grit is really all you need.
Also I bought these weld in tip tie tabs from TMR customs to keep my wiring clean.
Coastal offroad front bumper build guide-20210619_134712-jpg  Coastal offroad front bumper build guide-20210619_134720-jpg  Coastal offroad front bumper build guide-20210619_115728-jpg  Coastal offroad front bumper build guide-20210619_135502-jpg
Build thread:
Old 07-06-2021, 08:09 PM #22
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
Done
Coastal offroad front bumper build guide-screenshot_20210705-170758_facebook-jpg
Build thread:
Old 07-06-2021, 09:23 PM #23
montijo505's Avatar
montijo505's Avatar
Originally Posted by Jeremy_A View Post
Done
Turned out awesome! I love the dds3 amber, it’s a nice clean color. Any reason you went single hoop this time around?
Old 07-08-2021, 01:00 PM #24
mavrick1903's Avatar
mavrick1903 mavrick1903 is offline
mavrick1903 is on a distinguished road
What did you do with the washer tank?
mavrick1903 is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 06:58 PM #25
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
To fit side hoops bar needs tilted forward really far. I wanted it vertical
Build thread:
Old 08-25-2021, 06:59 PM #26
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
Bought a small classic car kit and moved it up near firewall
Modified this:
Universal UTV 12V Windshield Washer Bottle Tank Pump Wiper System Reservoir Kit | eBay
To use factory pumps
There is a unused bolt hole on inner fender near passenger firewall. Just mounted it there.
Build thread:
Old 08-25-2021, 07:02 PM #27
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
What is this? And why is it out?
Coastal offroad front bumper build guide-20210810_154525-jpg
Build thread:
Old 08-25-2021, 07:06 PM #28
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
LUX rocklights really light it up!
Coastal offroad front bumper build guide-fb_img_1629932672254-jpg
Build thread:
Old 08-25-2021, 09:15 PM #29
patrickufkes's Avatar
patrickufkes patrickufkes is offline
patrickufkes is on a distinguished road
Looks awesome dude nice job. Very impressive, makes me wish I could weld.
patrickufkes is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 01:33 AM #30
Jeremy_A's Avatar
Real Name: Jeremy
Jeremy_A's Avatar
Real Name: Jeremy
Basically learned on my own
Build thread:
bumper , coastal , offroad , pics , steps
Coastal Offroad Front Bumper sammoore422 4th Gen T4Rs 3 06-02-2021 03:54 AM
4th Gen Coastal Offroad Front Winch Bumper Kit djsixbillion For Sale: T4R Items 3 05-20-2021 03:13 PM
Coastal Offroad Front Bumper For A 5th gen sleepsontoilet 5th gen T4Rs 13 04-18-2021 10:44 PM
WTB: Coastal Offroad Front Bumper 3rd Gen jasonh Want to Buy/Trade 0 02-06-2020 12:01 PM
***For those interested. Coastal Offroad High Clearance Front Bumper Build*** jearred.foruria 3rd gen T4Rs 25 09-26-2019 02:48 PM
