Old 06-03-2021, 10:36 AM #1
LinuxHack3r's Avatar
LinuxHack3r LinuxHack3r is offline
LinuxHack3r will become famous soon enough
2007 SR5 4WD Wheel Bearing Replacement
I had new tires installed yesterday and the shop owner informed my I had a bearing going out. I have heard a slight noise but thought it was just noisy tires. I guess I was wrong.
I found a video last night and watched it...is it a relatively easy job?
https://www.youtube.com/watch?v=LId0MgZ37OA&feature=youtu.be
The last time I changed wheel bearings was on a 1998 Chevrolet Blazer with nearly 180,000 miles. I remember using a bearing puller and greasing it up rather a lot.
This Toyota looks completely different than what I expected...but at first glance the video looks easier. If it is that easy, and reason not to just do both rear bearings at the same time?
Which parts on RockAuto would be recommended?
2007 TOYOTA 4RUNNER 4.0L V6 Wheel Bearing | RockAuto
My Build Thread
2007 Toyota 4Runner SR5 V6
LinuxHack3r is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 11:19 AM #2
triethylborane triethylborane is offline
triethylborane will become famous soon enough
Its an easy job. The bolts on the caliper and hub are of a large enough diameter that should not shear even if your 4Runner is replete with corrosion. Penetrating oil, torch, some longer wrenches, and crows feet for torque specs are helpful but not necessary.
Timken and Centric.
Edit, if you want front hubs, which is what the gent in the video did, you need the integrated bearing and hub. SKF.
triethylborane is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 12:52 PM #3
Timken and Centric.
I'll be doing rear first, probably as a pair if it's a quick job. I guess I need to find a video showing rear bearing replacement, is it relatively the same?
My Build Thread
Old 06-03-2021, 02:35 PM #4
4th Gen Rear Wheel Bearing DIY
I do like this write-up.
My Build Thread
Old 06-03-2021, 02:37 PM #5
Timken and Centric.
It looks like the rear is quite a bit more involved than the front? The parking brakes have to be dealt with and from what I see the bearing should be pressed off and on with a press?
I've read that this can be done at NAPA, is that recommended?
My Build Thread
bearing , bearings , easy , time , video
Wheel Bearing Replacement ToyNutt 3rd gen T4Rs 20 02-29-2020 10:52 AM
About what mileage are front wheel bearing due on 2007, 4th Gen, 2WD, SR5? jow 4th Gen T4Rs 17 09-18-2018 08:34 AM
Wheel bearing assembly replacement help nysimonsez 4th Gen T4Rs 27 09-24-2014 12:26 AM
4th Gen 2wd front wheel bearing replacement phil123 4th Gen T4Rs 12 12-24-2013 10:10 AM
front wheel bearing replacement Forrrrest 3rd gen T4Rs 2 11-03-2012 06:38 PM
